how do I make manuel fan switch?
Old Nov 12, 2002 | 02:43 AM
Camarokid01's Avatar
I want to put a switch inside my car so that I can turn on the cooling fans when the car is off so I can cool it down at the track, does anyone have any directions on doing this?
Thanks in advance
Old Nov 12, 2002 | 02:51 AM
JPrevost's Avatar
Car: 91 Red Sled
Ground swith for the fan relay. One wire only.
Old Nov 12, 2002 | 12:50 PM
sorry I'm kinda slow but what does that mean? directions?
Old Nov 13, 2002 | 10:10 AM
89rsIMPRTETR's Avatar
hey camarokid, this is how i did it. take out your cd player and pull all the wires out from behind it, locate the wire for your air conditioning, i think it is orange, splice a wire into it, hook the other end to a switch, then ground the switch and walla! you should be able to turn your fans on whenever you want to, otherwise they will turn on normaly
Old Nov 15, 2002 | 06:45 AM
MdFormula350's Avatar
hers a pic of the relay...
Old Nov 15, 2002 | 06:49 AM
you can use a regular toggle switch..
good luck
Old Nov 15, 2002 | 03:19 PM
tpirocz's Avatar
Car: 89 IROC-Z & 94 Z71
Engine: both 5.7
Transmission: both autos
two ways to go about it. first up by the headlight pass side is the one of the fan relays. the gree/white wire is the ground wire. slipie another wire into that one. then ground it...directly above the relay is a screw into the frame of the car where it can be grounded. this methid will have fan on all the time.
the other way you could do it is, the wire you spliced and grounded; instead of grounding it under the hood, run it inside the car to a switch.then ground the switch. this will allow you to manualy control it.
i did this last weekend, took like 10 mins 15 tops.
Old Nov 17, 2002 | 04:30 AM
tpiroc, will doing the mod your way still let the fans work as they usually do? And when the car is off let me turn them on if I want to? or will the fans be stricly manuel?
eightsixseven
Dec 16, 2024 01:50 PM
RazorN8
Jan 7, 2022 11:44 AM
355sbcTPI
Aug 19, 2015 04:38 PM
TA8487
Aug 16, 2015 12:21 PM
Fronzizzle
Aug 9, 2015 01:15 PM
