220 and cold
Old Nov 22, 2002 | 09:56 PM
f-crazy's Avatar
Car: Bright Red 91 GTA
Engine: CARBED LT4
Transmission: MK6
220 and cold
this only happens during the cold months when i have to use the heat..when my car is at 195 and up the air coming out of the vents cool...almost like running the full cold setting without the A/C....and other times im sweatin...
im gonna check the thermostat tomorrow..maybe its stickin closed
any other ideas?...maybe the heater core?
if it is thats odd cuz that would be the third one in a year
later
Rob
Old Nov 22, 2002 | 11:06 PM
HamSpiced's Avatar
Car: 89 Camaro I-Roc z
Transmission: Th700r4
i had the same problem a little while back.. i diagnosed it as being the heater diverter valve. its that goofy looking mushroom thing, check to see if it has the vac. line atteched right and stuff.
Old Nov 23, 2002 | 07:31 PM
Andy Bush's Avatar
It could also be the vacuum line to the air diverter flap actuators, if you have the later model.
Third thermostat or third heater core.?
Old Nov 24, 2002 | 08:15 PM
MdFormula350's Avatar
definitely check the heater vavle thing.. something is just not letting the hot air get into the car..
Old Nov 25, 2002 | 07:09 PM
maddog's Avatar
why two heater core's in one year ?
Old Nov 26, 2002 | 10:37 PM
MrsLottaBallsCamaro's Avatar
My IROC never gets above 150*, and my heat is never warm either. It's just like outside air. Where would the heater divertor valve be?
Old Nov 27, 2002 | 08:50 AM
IROCmonkey's Avatar
Car: 85 IROC
Engine: LB9
IIRC...mine doesnt have one..its on the passenger side of the engine bay, just follow the heater lines from the firewall, its a little black housing I believe
Old Nov 27, 2002 | 11:57 AM
88Bravo's Avatar
Car: 1988 Pontiac Firebird, flat black
Engine: Stock 305 LO3
Transmission: Five speed
Did you install the the front of the heater box right? I know there is a wire that opens and closes the vent to let the hot air through. Just a thought, everything else have been brought upi that I can think of.
Old Nov 27, 2002 | 06:57 PM
f-crazy's Avatar
Engine: CARBED LT4
Transmission: MK6
i havent benn able to pop in here because of work...i havent drivine my car much in the last week or so...and today when i got home i put some more gas in it so i didnt get any condensation in the tank or lines...i cranked the heater on after my car had warmed up and in about a minute and a half i was opening the window...
why is it intermittent?
Old Dec 9, 2002 | 09:52 PM
My friend finally figured out why my heat wasn't working. The cable that connects to the Cold/Hot lever had come undone from the cold/hot air switch by the heater core, so it was stuck on cold air.
Old Dec 10, 2002 | 08:01 PM
82camaro's Avatar
Car: 82 camaro SC
Make sure it's completely full of antifreeze. How does the antifreeze look? If it's full of gunk, you might have plugged the heater core. Have you tried a new heater valve, or just bypassed the heater valve?
Old Dec 11, 2002 | 08:48 AM
HamSpiced's Avatar
here man i had time and i did the search for you...
and this is a previous post from a user a while back that couldnt figure out why he wasnt getting heat. hope i could help
https://www.thirdgen.org/techbb2/sho...diverter+valve
Old Dec 11, 2002 | 08:52 AM
HamSpiced's Avatar
And this is a pic of the heater diverter valve.
Spyder_TheGamer
Oct 2, 2015 12:25 PM
SS-EXPRESS
Sep 28, 2015 09:14 AM
mfp189
Sep 27, 2015 09:25 AM
86IROC112
Sep 11, 2015 04:04 PM
