Removing A/C
Old Dec 26, 2002 | 04:43 PM
IROC-Z5.7TPI's Avatar
Car: 88 IROC-Z
Engine: 5.7 TPI
Transmission: 700 R-4
Removing A/C
I want to remove my A/C out of my 88 IROC, the car thats described in my sig. Do you guys think it is worth it to go without A/C, I dont really use it, and my windows work well . So I was wondering if the lost weight of the A/C Cooler, and the Pump would be worth it, Im running a Serpintine belt system. I was wondering if All i need is the 1LE A/C Delete and if anyone knows what size the belt would be without the a/c pump.
Old Dec 26, 2002 | 07:52 PM
breathment's Avatar
if i were u i would also change over to a heat only blower box to clean up the firewall some. and get rid of even more weight. even though the evaporator only weighs like a pound.. but when u combine that with the weight of the compressor and the condesor (which will help get u more air through ur radiator too) then i can see it being a good thing. i think the whole a\c system weights like 46lbs..
Old Dec 26, 2002 | 08:43 PM
IROCZZ3's Avatar
Car: 87 Buick GN
Engine: 3.8L (231 cid) V6
Transmission: 200-4R
Axle/Gears: 10 bolt G80/ 3.42
It's up to you if you think it's worth removing your AC. Some people's comfort level is different than others. Some people think I'm nuts for not having AC in south Georgia. However, if yours still works I'd keep it. Mine didn't work and I never used it so away it went and I don't regret it. I did it to save weight, clean up the engine bay, and make everything easier to work on.
You can run the same belt you had before....the dummy pulley is the same diameter as the AC clutch pulley.
Old Dec 27, 2002 | 09:53 AM
MdFormula350's Avatar
last year i only used the a/c two times, only because it was raining and i couldnt have the windows or t-tops off.. i am thinking about getting rid of the a/c also.. i am going to start looking for the heater box and the pulley see what kinda prices i can find..
Old Dec 27, 2002 | 10:00 AM
bluegrassz's Avatar
Car: Camaro
Engine: Carbed L98
Transmission: TH350
The non-a/c heater box will be hard to find, and when you do find them they dont come cheap. I would love to have one, but I ended up making a plate for the top of the box. It helps some and ended up looking close to stock.
Old Dec 27, 2002 | 10:11 AM
i am searching ebay right now... trying to see what a a good price for the pulley and box would be.
Old Dec 27, 2002 | 10:15 AM
bluegrassz's Avatar
Car: Camaro
Engine: Carbed L98
Transmission: TH350
You can get the pulley from GM new for around $45.
Old Dec 27, 2002 | 10:38 AM
IROCZZ3's Avatar
Car: 87 Buick GN
Some people on ebay can be nuts. I was gonna last minute bid on a heater box but the price went up $100 in the span of 30 minutes! The winning bid was $153! I ended up getting one from http://members.***.net/iroczdave1/index.htm for $88 shipped.
Old Dec 27, 2002 | 10:44 AM
Blackroc86's Avatar
Car: 1986 Iroc
Engine: 454 Demon 850DP
Transmission: TH350, 3500 stall
I was able to get the non AC heater box from David T's in Edmonton Alberta for 25.00 CDN which is about 16.00 US. The website is davidt.com
Old Dec 27, 2002 | 12:34 PM
thats cheap!
Old Dec 27, 2002 | 01:17 PM
breathment's Avatar
don't forget that the ladies like A\C!!
Old Dec 27, 2002 | 09:52 PM
spartyon's Avatar
Car: 1986 camaro
Engine: 383 sbc
Transmission: th-400
Axle/Gears: 4th Gen 10 bolt/Detroit TrueTrac 4.
just tell them to get naked to cool off
i took out my ac and decided to rivet a piece of sheetmetal in the ac hole and cant find a non ac box cuz they are freakin rare so i was thinkin of finding a non ac gm car and puttin my heater motor in that box and possibly redrilling new holes for the box to mount or not having heat at all and using the control area for more gauges.
Old Dec 30, 2002 | 09:02 PM
Car: 88 IROC-Z
Engine: 5.7 TPI
What would I have to do as far as Taking the A/C out and do I need to get anything except for the new Pully in place of the A/C compressor?
Old Dec 31, 2002 | 09:59 AM
1989GTA350's Avatar
Car: '89 GTA
Engine: 427 BBC
Transmission: TH-350
does anyone have the GM part # for that AC delete pully
Old Dec 31, 2002 | 11:50 AM
https://www.thirdgen.org/techbb2/sho...+delete+pulley
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
HP52TA
Feb 3, 2018 10:51 PM
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
Ironhead38
Sep 7, 2015 02:26 PM
85Special
Sep 3, 2015 04:21 PM
