Cooling Fan Switch Question
Car: 1991 Camaro RS
Engine: L98 350 TPI
Axle/Gears: ZT LSD with 3.42 - LS1 brakes
I have a 91 Camaro RS and I'm looking for a cooler fan switch (one that doesn't turn on at 220*, but probably somewhere near 200* or less) Deos anyone know where I can get one? Also, how much would they cost? I live in California. Thanks for your time
-Tim-
-Tim-
Engine: 305 TBI
Transmission: th700R4
i went to a performance speed shop. they had to order it but usually they sell them but you should make sure you have the stat to match. I would suggest either making sure you have a 190 stat or buy a new one with your switch. but you should be able to find it at a speed shop.. idk if your everyday pep boys would have it
good luck
good luck
Car: 91 rs
Engine: Carbed 355 CR 9:1 xr276 cam
Transmission: 700r4 2600 stall
You can get a jet fan switch from summit for around $40 shipped on at 200 off at 185*. I just installed it to night it was a PITA i could not get anything in there to get the old one off deep socket hit the headers a short one would not go on finally got it after about an hour of work any way the part # for my 91 rs fan switch from jet is 60600
Car: 04 Xtreme Blazer
Engine: 4.3L V6
here is a cheap low temp switch, you would need just the switch(not the harness for the vettes(witch is a seperate part)
http://shop.store.yahoo.com/zipprodu...c5/pm-174.html
eightsixseven
Dec 16, 2024 01:50 PM
TA8487
Aug 16, 2015 12:21 PM
