Replacing Thermostat
Old Feb 13, 2003 | 10:54 AM
Tribe's Avatar
Car: 1992 Z28
I have a 92 Z with the 305 TPI. I need to replace the thermostat. But I have never attempted to do something like this before. Can anyone provide me with some guidance? I believe I have located where the thermostat is located. Also I have a 180 replacement, should I use a 195 instead? Thanks for any help.
Old Feb 13, 2003 | 01:53 PM
Thirdgen86TA's Avatar
As you are looking at the car it should be under the water neck to the right of the manifold. There may be a hose running from the radiator to the water neck. Just unbolt it, take the old one out and put the new gasket in and the thermostat and bolt it back up.
Old Feb 13, 2003 | 05:52 PM
patrickm00's Avatar
you don't need to drain any coolant, but to save a mess you should probably clamp the hose some, just don't put too much force on it (use a sheet of wood or something to distribute the force of the clamp)
Old Feb 13, 2003 | 07:27 PM
RMK's Avatar
RMK
Car: 87 IROC
Engine: modded LB9
Transmission: Pro Built 700R4
Just remember that when you are putting it back together that the thermostat sits in the little dish on the intake, then the gasket, then the housing. My thermostat came with instructions that told me to put the gasket on the mafifold then place the thermostat over it, then place the housing. Well I thought it wouldn't work, but followed the instructions, and yup....it didn't work. Started leaking.
I also used a little sealer on the gasket itself.
Also, does anyone know what to torque the housing bolts to?
RMK
Old Feb 13, 2003 | 07:56 PM
92 zzz28's Avatar
Car: Guess
Engine: Crazy 8
Transmission: So close to being a manual I can taste it
The torque is hand tight with a 3/8 ratchet is fine. Just make sure you clean all the old gasket off or you may have a pisser.
Old Feb 13, 2003 | 08:57 PM
patrickm00's Avatar
and stick a clean paper towel into the hole so while you're scraping off old gasket (razor blade or flat screwdrivers are fine) it doesn't fall into the cooling system.
Old Feb 13, 2003 | 09:18 PM
SpeedCat86's Avatar
Car: '86 TransAm WS6
Transmission: Custom TH700R4
Oh, yeah,
For the love of G0D, spray some Break-Out, JB-80, 3-n-1 or any kind of penatrating oil (even WD-40) on the thermostat bolts before you try to remove them. You really don't want to break one of the housing bolts. The steel bolts tend to galvanize themselves to the aluminum manifold, and sieze.
Old Feb 15, 2003 | 04:14 PM
92 zzz28's Avatar
Car: Guess
Engine: Crazy 8
Yeah, it really sucks when your half hour t-stat job turns into taking hours because you broke a bolt in the manifold!!
Old Feb 15, 2003 | 04:49 PM
patrickm00's Avatar
or when it takes a torch and tons of drilling because the previous idiot that owned the car took out the thermostat and EPOXIED THE BOLTS IN...
Old Feb 15, 2003 | 06:28 PM
jmon92conv's Avatar
one other thing, you may have to reove the throttle body to get to the bolts. This is simple, just remove the 4 front bolts and pop the tb off. Be careful not to screw up the gasket and you can reuse it(I have not messed up one yet, knock on wood). While you are at it, you could do the Coolent bypass while you are at it.
Old Feb 15, 2003 | 07:04 PM
MdFormula350's Avatar
you might as well use the 180 because you already bought it.
Old Feb 15, 2003 | 07:26 PM
patrickm00's Avatar
you really shouldn't need to remove the TB. one bolt should be easy to get with an extension, the other you might need an open-ended wrench though if the clearance is too tight. or try a small socket on a 1/4" ratchet if you can get it in there.
Old Oct 12, 2012 | 01:30 PM
JOEM's Avatar
Car: 1992 Z28 Convertible
Engine: 5.0 TPI
Axle/Gears: 2:73 L/S
Re: Replacing Thermostat
Does anyone know the torque specs???????? Has anyone warmed the engine to help free the bolts?
1992 Trans Am
May 10, 2023 07:19 PM
italiano67
Dec 11, 2016 09:21 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Wade787b
Sep 29, 2015 01:15 PM
perZ
Aug 15, 2015 01:17 PM
