Fan Shroud Question CHECK IT !!!
Old Mar 11, 2003 | 02:51 PM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
I have been told that GM recently stopped producing the bottom piece of the mechanical fan shrouds that early third gens had. They still produce the bottom piece. The part number for the top piece is 10029894 and the part number for the bottom piece is 10019577. I need a fan shroud, and I don't mind buying new (or used). Question is how difficult would it be to buy two top pieces and fabricate the bottom mounts?
Brady
Old Mar 14, 2003 | 12:31 AM
darbleinad's Avatar
Car: 84 Trans Am
why not just get a bottom piece for the wreckers? actually why not get the whole setup? perhaps setups from other GM rear-drive vehicles with mechanical fans will work too.
Old Mar 14, 2003 | 01:26 AM
ontogenesis's Avatar
Car: 1985 Camaro, 2015 Audi A4
Engine: V8
your going way overkill, what's a bottom fan shroud worth to you, i've got almost anything you need off an older camaro except engine and trans parts, tell me what it's worth to you cuz it's not worth much to me.
Old Mar 14, 2003 | 06:30 AM
mtws's Avatar
Classic Industries sell upper and lower fan shrouds for 82-85 with mechanical fans
Red iroc-z 305
Sep 30, 2015 05:22 PM
Hellbillydeluxe
Sep 22, 2015 09:58 PM
Fronzizzle
Aug 17, 2015 02:52 PM
redmaroz
Aug 16, 2015 11:40 PM
Leggman1
Aug 6, 2015 04:15 AM
