Temp gauge not working
Old Mar 23, 2003 | 10:50 PM
jcampbelljac_88's Avatar
Car: 92 camaro RS
Engine: 305 TBI
Just wondering if anyone can help. I have a 92 RS with a 305 and temp gauge will not budge at all no matter how long you drive. The only time it moves is when you start the car it jumps all way to max and then drops down to min and does not move. that leads me to belive that it is not a wiring issue but i could be wrong. I have already changed the coolant temp sensor and have no idea were to go from here but i belive the temp gauge not working is causing my fan not to come on when it is suposed to. Any help will greatly app.
Old Mar 24, 2003 | 07:28 PM
badboy's Avatar
you should have 2 temp sensors one for the dash guage and the other for the ecm to tell the fans when to come on , which sensor did you replace and did you test any of the sensors they can be tested
Old Mar 24, 2003 | 07:39 PM
Car: 92 camaro RS
Engine: 305 TBI
Changed the one by the thermastat. And no I did not test it did not know you could.
Old Mar 24, 2003 | 07:42 PM
badboy's Avatar
okay the one at the stat is the sensor that goes to the ecm for fan control there is another sensor cant remember at this time where its is but sounds like that one might need replacing generally they do burn out do any codes come up?
Old Mar 24, 2003 | 08:02 PM
Car: 92 camaro RS
Engine: 305 TBI
Haven't checked the codes but will here shortly and let you know.
Old Mar 24, 2003 | 08:04 PM
badboy's Avatar
okay
Old Mar 24, 2003 | 08:10 PM
Car: 92 camaro RS
Engine: 305 TBI
Just a code 12 that is all. How so you go about testing the sensors is it very hard?
Old Mar 24, 2003 | 08:17 PM
badboy's Avatar
no its not hard but you'll have to check on the site dont remember what section its under but find the one with the ohms resitance for sensors, then get an ohm meter clip it to the sensor wires and it will give you a reading which you'll have to compare from the chart in on of the sections if you get readings that dont match the chart then the sensor is no good if they do match then you might have an electrical problem
Old Mar 26, 2003 | 08:37 PM
c4boom's Avatar
Car: 87 iroc and 88 k2500 tbi truck
Engine: l98 and lo5
Transmission: 700 r4's babby
the sensor on the driver side head sounds like it is dead thats the one to the gauge
Old Mar 27, 2003 | 10:42 AM
Car: 92 camaro RS
Engine: 305 TBI
Thanks for the info i will let you know if it fixed it when I get around to working on it.
Ghettobird52
Jul 5, 2024 11:18 PM
Jeremys87
Jul 14, 2022 09:08 PM
Reddeath210
Oct 6, 2015 08:20 AM
Jk_Under
Aug 17, 2015 03:08 PM
bamaboy0323
Aug 15, 2015 07:20 AM
