How cold to go?
Old Apr 10, 2003 | 01:58 PM
TallWhiteGuy's Avatar
Car: 1990 rs, pride and joy
Engine: 305 tbi
Transmission: t-5
How cold to go?
Okay i have look and found some parts to get it to run cooler. First is having a 160* thermostat and 160* fan switch. too cold? or should i have the fan come on after the thermo
Old Apr 10, 2003 | 09:39 PM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
i would do higher then 160*, and definetly have the fan come on above the thermostat opening temp.
Old Apr 16, 2003 | 01:25 AM
jgifford's Avatar
Car: 1986 Z28
Engine: 355TPI 380hp
Transmission: Rebuilt 700r w/ Transgo Shift Kit
I agree, from what I understand, if you get anything under 180*, the system may never go into closed loop operation, according to TPI Fuel Injection Swapper's Guide.
Old Apr 16, 2003 | 04:36 PM
Danno's Avatar
Car: "02 z-28
Engine: LS-1
Closed loop will happen at about 110 degrees coolant temp. Thats just a reference temp that the O2 sensor and CTS pull it from open to closed loop. Anything colder than a 180 stat causes reduced gas mileage and generally a richer than normal mixture on EFI engines. This subject gets more than it's share of discussion and everybody seems to be an expert. Truth be told the engine runs it's best right around the stock 195 temp. A 180 is an acceptable compromise since the engine depending on driving conditions will still average around 185-200 degrees. And, it's not just emission related as far as temp is concerned. Almost every car and liquid cooled motorcycle run at 195. That's where engines are most efficient. Some GM's run a stock 180 stat but that's as low as I would go.
Old Apr 16, 2003 | 07:08 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
Are you running a computer? If not, I'd go 160*stat and fans come on around 180*/190*.
If it is computer controlled then a 180* stat and 190* fan switch would be fine.
Old Apr 18, 2003 | 10:45 PM
Tom91Bird's Avatar
Car: 1991 Firebird
Engine: 383 stroker
Or you could have one that is specifically built to run coolers like mine
Spyder_TheGamer
Oct 2, 2015 12:25 PM
ramicio
Sep 28, 2015 01:18 PM
SS-EXPRESS
Sep 28, 2015 09:14 AM
mfp189
Sep 27, 2015 09:25 AM
