runnig hot
Old Apr 13, 2003 | 09:54 AM
Scania's Avatar
Car: 1989 Corvette
Engine: 350 Tpi
Transmission: ZF 6 speed
Axle/Gears: Dana 44 3,33
runnig hot
I have a small problem whit the temp. First it runs at normal temp but now and then i increases to about 235F and then it cools down to normal. Very strange i think, both fans are running since i change the fan control unit so now they both kick in at the same time. Could there be a leak in the radiator cap so i get air in the system or could it be something worse like the head gasket.
Old Apr 13, 2003 | 10:20 PM
CAMAROsc350's Avatar
I had just about exactly the same problem your having with my other car, i would be on the highway and the temp would creep up to 220 then go down to like 195 and continue to do this over and over again. it turns out my thermostat was sticking i changed it and now the cars fine, change the thermo hopefully that will fix your problem.
Old Apr 13, 2003 | 11:51 PM
Drunken_Polak's Avatar
ill have to check that on mine :P
Old Apr 14, 2003 | 02:43 PM
Scania's Avatar
Car: 1989 Corvette
Engine: 350 Tpi
I changed mine only two years ago. Sometimes i can see bubbles in the canister that contains the cooling liquid. It seems that the coolant from the radiator ends up in that canister so i have to refill the radiator. Thats why im leening to a problwm with the radiator cap. Anyother suggestions?
Old Apr 14, 2003 | 04:25 PM
My thermo was only about 1 yr old when it went bad so you should change it anyway its cheap also change the rad cap. Bubbles mean you have air in the system, could be intake manifold gasket or head gasket at worst or it could be something minor. While the car is running coolant goes into the overflow tank its normal, are you leaking coolant? What color is your oil, is it milky or is it bubbly at all?
Old Apr 14, 2003 | 10:46 PM
TransAmTBI's Avatar
Engine: 305 TBI
Transmission: th700R4
some of the tpis were ment to run around 220 highway.. my friends trans am fan tyurns on at about 235 and shuts off at around 180so it usually stays around 220, id either get a different stat, new fan switch that turns on sooner, or put in a manual fan switch.
Old Apr 15, 2003 | 02:28 AM
Scania's Avatar
Car: 1989 Corvette
Engine: 350 Tpi
I change the thing that starts the fans so now they come on earlier. No the oil is fine no problems there and i get heat from the ventilation system so it shouldnt be the head gasket because usually the heat doesnt work then and you got coolant in the oil. I havent seen any leaks exept from the overflow tank thats because of the bubbles that squirts coolant.
Old Apr 15, 2003 | 02:41 PM
Scania's Avatar
Car: 1989 Corvette
Engine: 350 Tpi
Oh no she leeking ¨coolant somewhere. I filled the radiator with 0.8 liters today. When i drove home from work this evening i noticed a small pool of coolant. It seems to come from where the cat is located, behind the engine on the right side. What on earth could that be???? Any ideas?
Old Apr 15, 2003 | 02:57 PM
Have you checked the hoses at the heater core?
Old Apr 15, 2003 | 09:49 PM
TransAmTBI's Avatar
Engine: 305 TBI
your heter core might be bad or leaking thus relieveing pressure from within the cooling system... try rerouting the heter core hoses and see if it still overheats... or runs hot
Old Apr 16, 2003 | 03:04 AM
Scania's Avatar
Car: 1989 Corvette
Engine: 350 Tpi
When i filled the system again with coolant it doesnt run hot. I dont know if i filled to much coolant in the radiator so it overflowed. Its was a pool of coolant on the overflow tank. Maybe it came from there.
Old Apr 17, 2003 | 11:40 PM
If your rad is still cold after u fill it up...that could be a sign that ur Thermostat is bad....stuck closed...check it out
Old Apr 18, 2003 | 05:54 AM
Scania's Avatar
Car: 1989 Corvette
Engine: 350 Tpi
I found it!! Its the hose clamp to the heat package behind the engine. The clamp was lose thats why it was spraying coolant all over the engine ones it got hot. Thank *** it wasnt anything more serious.
Thank you all for your answers.
MoJoe
Members Camaros
33
Feb 6, 2025 09:47 PM
Thaney9
Oct 24, 2015 07:26 PM
SS-EXPRESS
Sep 28, 2015 09:14 AM
mfp189
Sep 27, 2015 09:25 AM
ironbmt
Sep 27, 2015 06:00 AM
