Tranny cooler
Old Apr 14, 2003 | 07:13 PM
80's Al's Avatar
Car: 89' RS TPI,04' HEMI Dodge Q-cab
Engine: 383ci
Transmission: TCI 700R4, 3400 stall
Axle/Gears: 12 bolt 3.73
Tranny cooler
I am planning on running a tranny cooler on my new AOD drivetrain, and I will by-pass the radiator completely.
Is this common, or should I NOT do this?
I was thinkin of runin a 10" fan on the tranny cooler, which I am sure this would be a great help. But is it completely neccesary?
Thanks in advance or TIA
80's AL
80' Berlinetta
89' RS (currently under construction for destruction)
97' BIG Dodge truck:hail:
Old Apr 18, 2003 | 10:01 AM
Z28 Boy's Avatar
Car: 1991 Camaro RS
Engine: GMPP 350 HO w/TBI
Transmission: 700R-4
Axle/Gears: 10-bolt w/3.73s
i think that most people DO run it throught the radiotor. i did with mine. not sure why...probably just because it is that much more cooling you get by putting it through it.
why do you want to bypass the radiator? just wondering...
-brian
Old Apr 19, 2003 | 08:01 PM
80's Al's Avatar
Engine: 383ci
Well, I figure the Radiator is gonna already be hot, how much is it REALLY gonna cool it? Plus, the tranny cooler is out in front of everything. So it will get air first.
I bent my own lines, so had the chance to just run right past it!! So I did.
I may get a 10" fan just to have one on there.
80's AL
80' Berlinetta
89' RS ( currently under construction for destruction)
Old Apr 19, 2003 | 09:59 PM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
Many don't run it through the radiator. I have heard that the radiator doesnt cool it all that much, if any.
TinnMann2
Canadian Region
16
Jun 18, 2017 05:10 PM
jrdturbo
Mar 31, 2016 02:58 PM
bjpotter
Oct 4, 2015 07:48 PM
FormulasOnly
Oct 2, 2015 05:52 PM
apie2546
Sep 5, 2015 07:40 PM
