normal operating temp?
Old Apr 18, 2003 | 12:32 PM
Sneaky/Stinky's Avatar
Dear Friends,
Has anyone got a similar setup to mine? My Camaro is a 1984 Z28. It has a carbureted 350 Small block. My question is this: what is the "normal" operating temperature for my engine? What would be running hot? Thanks for your input. The reason I am asking is because my engine stays around 220 degrees.
Love
me
Old Apr 18, 2003 | 12:50 PM
1986redbird's Avatar
220* is the normal operating temp for factory motors, if the 350 is a swapper then it sounds like someone reinstalled the factory temp thermostat. your motor should have a mechanical fan on it because it's an 84, if not and it has electric fans then they probably reused the factory set fan switch.
if you have a mechanical fan and want to lower the operating temp of the motor just put a cooler thermostat in it.
if you have an electric fan/fans then you will need the cooler thermostat and a fan switch with a cooler setting to match.
Old Apr 19, 2003 | 12:48 AM
breathment's Avatar
from now one lets make Subject titles pertain to the information in the post or they will be deleted..
Fanatic1074
Oct 3, 2022 05:57 AM
sheachopper
Jul 31, 2019 11:27 AM
Linson
Oct 1, 2015 09:50 PM
SS-EXPRESS
Sep 28, 2015 09:14 AM
ironbmt
Sep 27, 2015 06:00 AM
