Coolant Temp and Oil Pressure
Old May 24, 2003 | 04:25 PM
warrior_91's Avatar
Car: 86 T/A
Transmission: 700-R4 Auto
Whats a normal reading on a guage for the coolant temp and Oil Pressure? Thanks.
86 Trans Am
Old May 24, 2003 | 05:02 PM
92 zzz28's Avatar
Car: Guess
Engine: Crazy 8
Transmission: So close to being a manual I can taste it
Normal operating temps for a stock 3rd Gen is around 220. If you live in a hotter or cooler climate you may see some differences.
Normal oil pressure is harder to say. Ideally you want as much oil pressure as you can get to a certain degree. About 10psi per 1000 RPM is considered acceptable. My engine, for example, has about 70 psi @ 2500 cold and 55 psi at operating temp. At idle, I have about 55-60 psi cold and 30 psi once warmed up. I have an Auto Meter guage, I don't trust the stocker...
Prodigious
Oct 4, 2015 11:20 PM
Bstrang6
Sep 8, 2015 04:29 PM
solocus
Sep 2, 2015 12:14 PM
bamaboy0323
Aug 15, 2015 07:20 AM
