High Volume Water Pump???
Old Jun 22, 2003 | 09:29 AM
pjd1959's Avatar
Car: 1983 Z28 (RED)
Engine: 305 HO
HELLO ALL:
I've got a front seal leaking, so since my 1983 Z28 305HO CCQjet still has the original water pump, might as well replace it while I'm at it. I've bought alot of stuff from SummitRacing and have been pleased with the results. They offer a "high volume" pump, but they're asking whether it's the long or short version. I figure mine is the short version, but before I order today, ........ just wanted to make sure and get some info from you experts.
THANKS
PAT
Old Jun 22, 2003 | 06:23 PM
92 zzz28's Avatar
Car: Guess
Engine: Crazy 8
Transmission: So close to being a manual I can taste it
You most likely have the long version. Short pumps were used on corvettes and a few other cars that had very cramped engine compartments. If you look around at websites you will probably find some schmatics, use those to be sure. My best guess without seeing it is you have the long pump...
Old Jun 22, 2003 | 06:31 PM
spartyon's Avatar
Car: 1986 camaro
Engine: 383 sbc
Transmission: th-400
Axle/Gears: 4th Gen 10 bolt/Detroit TrueTrac 4.
i say long as well. did you look into the stewart water pumps? very nice quality.
Old Jun 23, 2003 | 07:02 PM
T/A gets T&A's Avatar
I'd look at the stage 1 stewart if I were you. It's much cheaper than one of the aluminum 'high flow' pumps, and is certainly cheaper.
evilstuie
Jan 9, 2020 08:29 PM
Bubbajones_ya
Aug 28, 2015 02:17 AM
Dialed_In
Aug 20, 2015 01:45 PM
BBSDesigns
Aug 11, 2015 07:39 PM
