Is Dexcool synthetic?
Car: "02 z-28
Engine: LS-1
Dexcool is a manufactured OAT, or organic acid technology based coolant. In the strictest sense you could consider it a synthetic. There is much more info about OAT based coolants on the net then you are going to get here. Supposedly Dex does not form the scaling and is not as prone to corrosion with aluminum components as conventional coolant and it is silicate free prolonging pump seal life. It does have one drawback, if mixed in the wrong proportion or if the system is low and the vehicle is run for a prolonged period it will form a muddy residue the requires a chemical flush to eliminate. GM addresses this in a technical bulletin. Another benefit is that it is 100% biodegradeable, so it is more environmentally safe. It has the same toxicity as EG so don't stick it in a used orange juice container. Texaco invented it for GM, they have a lot of material data sheets for reprint.
Car: 89 Formula 350
Engine: 360 / HSR
Dexcool eats away at gaskets. I don't have any info to back this statement up other than my own personal observations in the automotive repair industry...but I have seen it many times.
thanks, I'll keep that in mind, but all I wanna know is what coolants are synthetic? I'm gonna flush my system out and was looking at replacing it with prestone, but was just wondering if it's synthetic, or if any coolants are synthetic?
Car: 1986 IROC
Engine: 355 Tpi
Axle/Gears: 9 Bolt 3.27
Also don't overheat it with dexcool. I replaced the coolant in my mom's v-8 jeep with dex-cool. The lower hose failed and she overheated the hell out of it. Ever since I have to flush the system once every 6 mos to get the hard deposits out of it. I can tell when its due because the hoses sound crunchy. The dried up dex-cool crunching inside the hoses
Car: "02 z-28
Engine: LS-1
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
if you're thinking of switching, be aware that if the older style "green" coolent mixes with dex-cool it forms a brown scale that cloggs up the whole cooling system..
Car: 1989 IROC-Z
Transmission: 700R-4
I was looking at that Peak pre mixed stuff last time I was at Kragen. It comes pre mixed, 50/50 with distilled water. It says right on the bottle, DO NOT MIX WITH WATER. Seems kind of convenient if you ask me. The lady said it sells really good. Opinions on this stuff? And does anybody recommend using that prestone coolant system flush before I fill up the radiator? Oh and, how much coolant does my system take? Like two or three of those big jugs of coolant? Not sure if those are gallon sized or larger. Thanks.
Car: 91 Camaro Vert
not worth it to me, but im not THAT lazy.
anyhoo, yea, that coolent flush works real well, esp if you use their reverse flush system thing too..
Car: 1989 IROC-Z
I know what you're saying but it was the same price as all the other stuff on the shelf, and it had distilled water in it, which would save me a trip to the store. So if it was the same price, exactly 50/50 mixed, I don't see how it wouldn't be worth it.
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
if it was half the price of the non premixed it would. But at the same price, it will take 2x the number of bottles to fill the cooling system. I just buy the non-mixed and get distilled water from the local grocery store in the center of town. its only like 50 cents a gallon or so.
Car: 1989 IROC-Z
How many jugs coolant/water will my system require? I now see what you mean that you would need to buy 2x
So I am assuming the system will take one jug coolant and one jug distilled water. Is that right?
So I am assuming the system will take one jug coolant and one jug distilled water. Is that right? Supreme Member
Car: "02 z-28
Engine: LS-1
I just think I'm gonna stay away from the dexcool. I don't know much about what coolant is made of, and I would like to have the best for my car. Is the regular green coolant from Prestone synthetic? If not, are there any synthetic coolants available that won't cause the adverse effects of dexcool? I really do appreciate all this info guys. I dunno what I would do without it.
Car: 1989 IROC-Z
25- If I were you I'd just stick to the normal green prestone. I don't think that is synthetic...just the glycose stuff (forget the entire name.) That's what I'm going to do, but can anyone please tell me about how many gallons of coolant my system will hold? Also, when flushing my system and filling it with fresh coolant, is it important to have the engine running with the cap off? Thanks.
Car: 91 Camaro T-Tops
Engine: 3.1L
Isn't Dex-Cool a SPECIAL coolent? If the car is meant for Dex-cool then that's what you are supposed to use. If you use anything other than Dex then you will screw up everything in the coolent system. Plus it won't keep the car as cool as the coolent it was meant for. I've seen lots of people put Dex in a regular car and they sprout leaks all the time. Same thing with regular coolent, if you try to put dex in it then not only will you not keep your engine cool, you will also sprout leaks. Just use the coolent the car was made for and you will be fine.
Dex cool has a different BOIL point than regular green coolent. Thats something else to consider. Plus the coolent lubricates the water pump, lots of times i've seen a water pump go out cause it wasn't lubed properly, and those are the people that switched from green coolent to the Dex cool.
Car: "02 z-28
Engine: LS-1
Car: "02 z-28
Engine: LS-1
Prestone makes a decent chemical flush mix, I generally use thier flush kit they sell at the chain stores. The factory uses a sealing tablet in new vehicles, however GM in a TSB says it's not required and I have not done it with any vehicle. Texaco who formulated Dexcool for GM recommends you do 2 flushes approx 2 wks apart to reduce residual EG coolant cross contamination. Many dealers and drive through lube places can do a dripless flush and complete exchange of the coolant with Dexcool but it's pricey. I like it because it extends service intervals and I hate messing with anti-freeze.
Engine: 3.1L
I wasn't to sure about the coolent. I figured if the came originally came with Dex-cool or GO-5 then thats what you should use. Since his car didn't come with dex I figured you should stay with the Green coolent. As far as leaks, I've seen people mix the Dex and the Green and things screw up, like the cooling system.
Tell me what the difference is between the different coolents?
Car: "02 z-28
Engine: LS-1
Mixing is a no-no and will create compatability issues, that's why they recommend 2 flushes 2 wks apart. Dexcool is an Organic Acid Technology based coolant and is 100% biodegradeable. It is low silicate and remains more stable than EG for much longer. All manufacturers are striving for lubricants and fluids that meet or exceed the warranty period and also for environmental concerns. Some areas of the country, local townships are trying to ban at home oil changes, coolant changes etc. Dexcool was an attempt to address these issues as well as providing a long term stable coolant for their engines which have more and more aluminum components. The 2 coolants work equally well as far as providing freeze protection and corrosion inhibitors.
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
My 96 GMC Sierra pickup came from GM with Dex-cool in it. The system was never touched & in less than 24,000 miles the overflow tank developed some nasty cystalization. The radiator, thermostat, recovery tank & hoses all had to be replaced at the Generals expense. I worked at the dealer at that time & we did countless similar repairs.
Car: "02 z-28
Engine: LS-1
