Fans not turning on!!!!
Old Jul 15, 2003 | 10:31 PM
jayhah2's Avatar
Ok, I have tried close to everything to get my fans to turn on. I tried some trouble shooting, but still no luck. The relay is new, I just installed a new Hypertech Fan Switch and still no luck. If anyone could help with this it would be greatly appreciated.
Thanks,
Jay
Old Jul 16, 2003 | 11:15 AM
MdFormula350's Avatar
so you verified the motors work?
have you check the fuse?
Old Jul 16, 2003 | 12:51 PM
JohnSowards's Avatar
I had the same problem, instead of changin it I went out and bought a switch and some wire, spliced into the line and now i run it that way. Not the best way to do it but at least it works.
Old Jul 16, 2003 | 01:00 PM
Diablo3Z28's Avatar
Car: 1986 Camaro Z28
Engine: Built Vortec 350
Transmission: 700 R4
As posted earlier "are you sure the motor works??" I had a problem with mine that the fan didn't come on either. I ended up splicing wires too and had the fan rigged so that it comes on when the key is in the ON position. My fan stays running now regardless.
Make sure the fan motor is working
Check fuse
Old Jul 16, 2003 | 01:06 PM
That could be a problem too, if the engine got hot a few times then the fan could have warped, check to see if the fan turns freely by hand. If not then theres your problem.
Old Jul 16, 2003 | 01:52 PM
jayhah2's Avatar
The fans do turn freely, the fuse is fine, and the fans do work when grounded. The only other thing that I thought might be wrong is the Air Temp sensor or the computer is screwed.
Jay
Old Jul 16, 2003 | 08:00 PM
Catchen22's Avatar
Car: 91 Camaro T-Tops
Engine: 3.1L
just check all your connections.......I had the same problem....installed a new motor, no luck. Everytime I turned on the AC the fan would work but when I turned the AC off the car would over heat. It ended up being a sensor I think. If your fan turns on when you turn the AC on the start with a sensor.
Old Jul 16, 2003 | 10:46 PM
jayhah2's Avatar
Thats the other thing, the fan, or fans wont even kick on when the AC is on. Ill eventually figure it out, thanks everyone for your help.
Jay
Old Jul 18, 2003 | 12:13 PM
Dustin Imports's Avatar
Car: 1988 Medium Orange Metallic IROC
Transmission: 700R4 transgo shift kit
Axle/Gears: 4.10 in box lol
quick question for you guys.
red and black coming off of each individual fan (daul fan app)
if I ground the black wires the fans will come on when key is turned to start car and when car is running..
regardless of all the other sensors and relays???
Old Jul 18, 2003 | 06:43 PM
RPM WOT L 98's Avatar
That won't do anything, DustinImports.
The black wires are actually grounded already, behind the right headlight. You need to ground the relays for the fans and they will then come on depending on how you ground them.
Old Jul 27, 2003 | 11:18 AM
92 z28's Avatar
i have the same problem, what sensor are you reffering to? if its the one on top of the tbi intake manifold i changed that already. what else can it be? if your gonna say the fan switch, i changed that already to. this is starting to drive me nutz. thanks!
Old Jul 27, 2003 | 12:32 PM
BoDeaN's Avatar
Car: '86 Transmaro
The sensor that tells the computer what temp your car is at is the Coolant Temp Sensor. The computer will then ground out your fan circuit turning on the fan. On my TPI, it is located right below the throttle body and hidden by a hose. Sorry, I'm not familiar with the TBI intake setup. I just had this problem and it turned out that my fan motor was burnt out.
Old Jul 20, 2008 | 07:10 PM
allgood's Avatar
Car: 92 WS6 Trans am convertible
Engine: ls 6.2
Transmission: 4l80
Axle/Gears: 2.73's
Re: Fans not turning on!!!!
i have 92 trans am and my fans are not comming on, so are there a fuse , relay, etc.
Old Jul 21, 2008 | 10:10 AM
Reid Fleming's Avatar
Car: 1989 GTA
Engine: SuperRam 350
Transmission: Pro Built S/S TH700R4
Check out my sig
Old Jul 21, 2008 | 01:57 PM
Gordiggz's Avatar
Car: 1983 Z-28
Axle/Gears: ?
I went with the toggle switch approach. I like the idea of being able to control as much as possible under the hood. Not to mention my amber light-up switch is a perfect color-match to the dashboard illumination on the 'bird. Also helps to suck some cool air in the compartment when you're in staging lanes at the dragstrip and the car is off.
RazorN8
Jan 7, 2022 11:44 AM
83 Crossfire TA
Jan 3, 2016 01:26 PM
bryanwood74
Sep 24, 2015 09:50 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
