Coolant flush question
Old Aug 20, 2003 | 09:09 AM
91GTA350's Avatar
I want to change my coolant asap and I have a quick question,
What exactly is involved with flushing your radiator?
I have never done this before and I believe its a simple job, but i just wanted to make sure before I get started.
Please let me know asap.
Thanks:hail:
Old Aug 20, 2003 | 09:53 AM
Briansz28's Avatar
Prestone makes a kit that has some fittings you spice into your hose. You hook a garden hose onto it for flushing.
Old Aug 20, 2003 | 10:02 AM
91GTA350's Avatar
Thanks. ABout how much coolant do you think i will need, and how much usuall drains out when flushing?
Old Aug 22, 2003 | 05:47 PM
Slow2.8's Avatar
ALOT drains out, make sure you put Down PLENTY and i mean PLENTY of newspaper... it gets messy.. when i did mine i wanted to use more water, to make it run cooler... so i just put in one gallon of antifreeze and dowzed the rest with water. Temp never sees close to 220
Old Sep 2, 2003 | 07:34 PM
REDRAGTOPRS's Avatar
Flushing the cooling system can be done by you, but is pretty useless in my opinion. The only real effective way to flush the cooling system is with a backflusher. These force the coolant out in the exact oposite way from which the coolant usualy flows through the engine naturally. What this does is agitate the rust, scale, and debris inside your engine, and forces it out instead of flowing right over it. It creates much more resistance in the system, and is the only true flushing method.
Old Sep 9, 2003 | 10:11 PM
ZROC86's Avatar
Car: 1999 Trans Am WS6
Transmission: A4
just did this to the IROC. I got the radiator cleaner and the backflush kit from prestone. worked pretty good. my engine heats up really fast now though. any thoughts on why? to much anti-freeze and not enough water?
Old Nov 12, 2003 | 05:29 PM
gearhead0384's Avatar
Car: 1989 Camaro IROC-Z
Engine: L98 350 TPI
Transmission: Built TH-700 R4 (Vilgilante 2800)
Axle/Gears: 9 bolt w/ PBR's
Where do you hook the backflush kit to??
Kevin
Old Nov 12, 2003 | 09:41 PM
breathment's Avatar
heater hose. going to the heater core.
Old Nov 13, 2003 | 02:44 AM
Engine: L98 350 TPI
How much money are they?
Kevin
Old Nov 13, 2003 | 12:07 PM
breathment's Avatar
like $3 at the most.
eightsixseven
Dec 16, 2024 01:50 PM
jbates346
Car Audio
25
Jun 10, 2020 08:27 PM
LittleFranks
Sep 17, 2015 12:22 PM
Bubbajones_ya
Aug 28, 2015 02:17 AM
redmaroz
Aug 16, 2015 11:40 PM
