Air Dam
Car: 94 Corvette
Engine: LT-1
Transmission: Freakin Automatic---For Now
Look on ebay. Ther is a guy that sells 'em 3 at a time. They are listed as 83-90 Trans Am Deflector Kit, but all you need is the center section. Trust me it works for a Camaro just fine. For that matter, it rocks on a Firebird.
Car: 1989 IROC
Engine: 5.7 / 350 cuid
Yeah, you're best bet is the guy GTA-SPD mentioned. Here's his phone number so you can save yourself the time on EBAY: 305-769-0985. This guy is unbelievably nice and knowledgeable and will get you set up and should give you all the information and ship times over the phone. ALl you need to know is the year of your car and he'll take care of the rest for you.
Car: '89 Camaro Convertible
Engine: LB9 Heads/LT1 Cam Holley 670 Carb
Transmission: T5 Manual
I cut my air dam almost in half. It dosen't hit the ground any more and it still cools like mad. It dropped the temp by like 30 or 40 degrees.
Did any one read the Q&A in Chevy High Performance about the air dam? Supposedly, a low pressure zone is created below the nose of the car and if you don't have the air dam it allows hot air from the engine compartment swirl back in front of the radiator.
I have a camaro and I have been thinking of getting a tpi airbox that goes above the radiator to capture the cold air that comes in and shoot it right at the air cleaner. I suppose I could also get a box for the air cleaner and put a hose between like the tpi set up.
That would really make a difference once the temp drops to about o degress and I run in the twelves. Joking.
Maybee that's what nitrous is for.
