getting scared.
Old Oct 11, 2003 | 10:50 PM
icebird_1981's Avatar
getting scared.
hey guys, i got a carbed 350 modded and the rad i am useing it from a 305 lg4 i no its to small because i have a hose on the bottom in order to get it to sit in the shroud. the rad is not damaged or anything like that> what i am wondering is should i be doing this?
also when i start my car from being shut off all nite is like 30% more faster then it is after driveing it for about 30 min> should it be that big of a diffrence, or is it from the rad?
thanks
Old Oct 12, 2003 | 09:22 AM
mikes92rs305's Avatar
the radiator should be fine. does it heat up quickly? does it overheat? our cars are faster when first started because there is no heat in the block and running very cold.
Old Oct 13, 2003 | 07:24 PM
no she has never over heated on me, i dont no if she heats up fast i will check tomorrow. here is a pic of the rad, its a bit small>u think i should be fine though?
Old Oct 18, 2003 | 07:13 PM
slinkh's Avatar
I swapped out my 305 for a 350 and kept the stock rad. I've only had any problems on really hot days in stopped traffic. It gets hot but never overheats. No reason why you shouldn't be fine.
Old Oct 29, 2003 | 04:34 PM
sqzbox's Avatar
Car: 88 formula WS6
Engine: 305 Lo3
Transmission: 700-R4
Have you checked the bottom hose to make sure it isn't being sucked flat by the pump when the thermostat opens? There should be a spring coil inside the hose or be a ribbed type to keep this from happening.
Randomtask2
Aug 5, 2015 12:39 AM
mcrandrz
Aftermarket Vendor Review
45
Apr 2, 2014 07:21 PM
Slow87
Jun 16, 2012 09:05 PM
CaliBranden
May 29, 2012 04:57 AM
88Camaro350
Theoretical and Street Racing
May 12, 2003 12:26 AM
