radiator shroud for deflected air cooling
Old Nov 10, 2003 | 12:38 AM
joshwilson3's Avatar
Old Nov 10, 2003 | 06:44 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Below I have a pic of some sort of lower air deflector for firebirds that I found on eBay. Is this one of the pieces that I need? And what is it's correct name?
That which you have pictured would actually be the upper air baffle for a TBI or carb'd Camaro. It goes between the fascia and the radiator support. The opening is for the hood latch.
Kind of like this...
Old Nov 11, 2003 | 12:59 AM
Old Nov 11, 2003 | 02:29 AM
deadbird's Avatar
Engine: TPI 305/ v6
Yea, it fills in the void where the airbox housing would be on a TPI/MPFI Camaro.
If you pop the hood of your bird, you might notice it looks a little different... sort of like this...
Old Nov 11, 2003 | 02:32 AM
deadbird's Avatar
Engine: TPI 305/ v6
While my air dam is slightly different from original, the other pieces were saved from the original bird nose... some part numbers/diagrams can be found on my site if you check my sig..
Old Nov 12, 2003 | 03:14 AM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Four pieces total that connect together to the radiator support:
10118485 Lower Center Air Deflector
10118488 Middle left Fender to Rad Support
10118489 Middle Right Fender to Rad Support
and I'd have to look at the fourth piece to tell you the P/N, but I can tell you that from GM this costs about $200 total. It's a bytch, but you have to get them to keep the engine cool!
Old Nov 12, 2003 | 06:42 AM
JPrevost's Avatar
Car: 91 Red Sled
I removed everything except the lower air dam and have had no problems with overheating. That's with the 350ho crate motor, stock radiator and stock fan.
The only advantage of that plastic piece is to hold tools .
I even removed that middle brace which holds the nose up and has the hood latch. It doesn't do anything anymore since I've got a pin-on. I'm in the process of making a few supports just because I fear the frond end will sag over time. It already has shrunk, damn urethane, lol. Anybody have a BRAND new front clip they want to send me? I'll pay shipping and give you a fiberglass clip in exchange. I just can't make the mold from mine... it's too small .
Old Nov 12, 2003 | 12:22 PM
Old Nov 12, 2003 | 12:26 PM
Old Nov 13, 2003 | 06:40 AM
JPrevost's Avatar
Car: 91 Red Sled
Originally posted by joshwilson3
Do you have pics of the stuff you took off. I might be interested in buying them.
thanks
Sorry, I tossed it all in the trash.
Old Nov 13, 2003 | 03:44 PM
deadbird's Avatar
Engine: TPI 305/ v6
On my car, where the hood laches down, it is all metal. There are no holes or anything that would be there for a TPI car. So I guess I don't need that top plastic piece that I listed above cause I have TBI, and there are no holes there for the TPI.
And yes, in your pic, I would say mine looks like that, just a big piece of metal with no holes or anything. Why did they make that air deflector for? Was it for someone switching from TPI to TBI?
That plastic piece is a filler piece made for camaro's only (the one I attached is from my tbi camaro). The mpfi camaros had a 'Y' shaped airbox that went over the top of the rad. support and had filters where that plastic piece is.
Even if you had a TPI, you would still have that some metal piece on your car. The firebird got a slightly different (crappier, certain years) airbox setup that terminated next to the EVAP canister.
Whoever listed that plastic piece on Ebay for a Firebird, listed it for the wrong car.
Old Nov 14, 2003 | 01:00 AM
Old Feb 11, 2007 | 11:35 PM
86-Iroc-Z's Avatar
Car: 86 IROC-Z
Engine: 305 V8 carb'd
Sorry to raise this thread from the dead, but does anyone have a PN for this?
Thanks,
Old Nov 26, 2007 | 06:13 PM
426 Wedge's Avatar
Car: 86 WS6 TransAm
Engine: LG4 4BBL
Transmission: T5WC
Axle/Gears: 327
Re: radiator shroud for deflected air cooling
Did you ever come up with the part # for the 4th piece? I know it's been a while!
Old Nov 26, 2007 | 10:17 PM
Engine: 2.7L V6
Axle/Gears: 4.41
Cant swear to that part number for the lower air deflector. I'll look at it tomorrow if it's not raining and get it for you. It does begin with a 102 number, and AFAIK, most of the air dam parts have disappeared from the GM inventories.
1992 Trans Am
May 10, 2023 07:19 PM
83 Crossfire TA
Jan 3, 2016 01:26 PM
krisner89
Oct 10, 2015 06:03 AM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
