Hairline Crack in radiator
Old Nov 30, 2003 | 11:43 AM
ecuxc's Avatar
Car: 1990 Camaro RS
Engine: 305 TBI
I have a hairline crack about an inch long at the top of my radiator on the drivers side. A little bit of fluid ****** out from it but nothing big. Can this be patched up with some kind of a sealant or should I just replace the entire core? Thanks for the advice.
Old Dec 1, 2003 | 12:26 AM
breathment's Avatar
well.. if you have a crack in your radiator in one spot, chances are other spots are about to go. you can only buy so much radiator fix before u need a new radiator.
Old Dec 1, 2003 | 09:00 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
can should and prefer are all diffrent things.
you COULD scrub the area clean and epoxy over it.
you SHOULD have a radaitor shop look at it and possibly braze over it.
athough i would PREFER to replace the entire thing.. (aftermarket alum is great)
Old Dec 1, 2003 | 11:17 AM
ecuxc's Avatar
Car: 1990 Camaro RS
Engine: 305 TBI
I appreciate the advice guys, thanks. I'll probably end up getting a new radiator so I dont have major problems in the future.
Old Dec 1, 2003 | 10:49 PM
Petes 84Z28's Avatar
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
You could prolly get the tank replaced at a rad shop for 30 bux or so.
Pete
Old Dec 1, 2003 | 11:08 PM
reilly8282's Avatar
Car: 1988 IROC
Engine: l98 350 tpi
an old mechanics trick, pour a little pepper in there.....see if the leak stops a little....
Old Dec 2, 2003 | 10:53 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
this does work great on a pinhole radiator leak.... i used it on the spitfire about 4 years ago and it hasnt leaked a drop since.
however, it doesnt work for anything other then a pinhole leak... so it wont help too much with a crack.
Old Dec 4, 2003 | 06:33 PM
Dubbs2u's Avatar
Car: 88 formula
Engine: tick tick tick
Transmission: slipping one
Re: Hairline Crack in radiator
Just go to www.overnightradiator.com... I think I paid $120 for mine...
Wendell
MoJoe
Members Camaros
33
Feb 6, 2025 09:47 PM
sheachopper
Jul 31, 2019 11:27 AM
86IROC112
Nov 7, 2015 06:50 AM
TheCardinal
Interior Parts Wanted
Oct 9, 2015 09:43 PM
92projectcamaro
Sep 29, 2015 07:07 PM
