Little Confused
Old Dec 21, 2003 | 01:44 AM
nj88's Avatar
Car: 1988 formula 350
Transmission: auto
Little Confused
i installed a 160 therm, on my 88 formula 350 and in traffic the car still reaches high temp around 200-220 is there anyway to fix this problem. thnx guys
Old Dec 21, 2003 | 10:16 AM
Dave Y's Avatar
Car: 04 Xtreme Blazer
Engine: 4.3L V6
that temp is normal
if you want it lower, dual fans need the chip reprogrammed(lower fan turn on) or a manual switch
single fan needs a lower temp fan switch, or a manual switch
Old Dec 21, 2003 | 03:56 PM
MdFormula350's Avatar
the stat will open earlier that doesnt mean without the fan being on it will keep cooler, it will just keep the engine from getting hotter quicker since u lowered the open temp.
the easiest is to get a lower fan switch or just wire in a manual fan switch, u will find great info from running some searches.
Old Dec 26, 2003 | 02:28 PM
lb9mm5's Avatar
Car: 89 Formula
Engine: LB9
Originally posted by Dave Y
that temp is normal
My formula runs between 220-240. you said that I need the chip reprogammed(I have the dual fans), where is this chip located, and how do I reprogram it?(even though I think my temp is normal, maybe it should be a little lower??)
Old Dec 26, 2003 | 07:18 PM
180 stat is very nice to have.
normal stock temp i found it to be 220 on the guage.
the easiest and cheapest is to wire in a manual switch, the dual fan diagram showing how to wire it in is all over the cooling board.
Galaxie500XL
Feb 1, 2020 04:53 AM
Jorlain
Oct 8, 2015 01:57 AM
sahlomonic
Sep 20, 2015 07:15 PM
bubbaz28
Sep 18, 2015 02:09 PM
Denricci22
Sep 18, 2015 09:02 AM
