coolant fan switch
Old Jan 7, 2004 | 06:40 PM
Jackman5003's Avatar
Car: 1984 S-15
Engine: 1988 Iroc-z 305 V8
Transmission: T-5 (5-speed)
coolant fan switch
is this whut i need? its the switch that grounds out when the temp gets to a certain point and turns on the fans....
http://www.napaonline.com/cgi-bin/nc...9&prmenbr=5806
if thats not it its the first part... because nap uses's this part number also for the collant temp switch for a lgihted car(prolly exact same thing)
ECHFS112
also does anybody know the part number for the connecter for this thing? gm or napa or w/e i juse need it. unless sumone has one??? cause..lol..all i got is the metal part and the lil rubber part....
Old Jan 7, 2004 | 07:07 PM
Dave Y's Avatar
Car: 04 Xtreme Blazer
Engine: 4.3L V6
that looks like it
dont know on the pigtail, but pep boys stocks them
if i remember tommorrow, I'll get a P/N
Old Jan 7, 2004 | 08:36 PM
Car: 1984 S-15
alright thanks...i found an extra one in the basement witta buncha connecters...the damn thing was broken tho
Old Jan 8, 2004 | 05:15 PM
Dave Y's Avatar
Engine: 4.3L V6
i forgot, I'll try to remember again tommorrow
Old Jan 8, 2004 | 05:49 PM
Tremo's Avatar
Car: 88 IROC-Z - original owner!
Engine: LB9 with K&Ns, MSD, Foil, Taylor
Transmission: WC T-5
Axle/Gears: BW 9-bolt, 3.45 posi
The stock factory fan switch that screws into the pass side head turns on the fan when the engine gets pretty damn hot. Like 230 or so. Real hot. You can get an aftermarket switch from Jet that turns on the fan at a lower temp.
I also heard that the fan switch from a 87 Buick GNX will work in our cars, and it turns the fan on at a lower temp than the stock Camaro unit. Anybody confirm this? Basically I think the stock switch turns on when the engine is too hot, and the Jet switch too cold, I'm looking for something in between.
Old Jan 8, 2004 | 06:19 PM
Dave Y's Avatar
Engine: 4.3L V6
I am running the fan switch for a 87 Buick t-type, which is pretty much a GN in standard regal clothing, it is for a 87 buick t-type, vin 7
it turns the fan on at approx. 220, off around 200
Old Jan 8, 2004 | 09:07 PM
Car: 1984 S-15
alright maybe i'll use an engine driven fan...haha...this is goin into an '84 s-15 by the way...and my brother said he'd make me a new setup for the fans with that switch as he did with his car becasue the stock setup is to damn confusing and cluttered up alot.
Old Jan 8, 2004 | 10:06 PM
Tremo's Avatar
Yo Jack, I'd use the Buick turbo v6 switch rather than the Camaro switch since it turns on the fan at a lower temp. The electrical switch functions and connectors are the same. Threads are the same. It just switches at a temp that is more friendly to the engine.
Old Jan 20, 2004 | 10:13 AM
Car: 1984 S-15
heh...a little late. turns out that i rad this after i bought the switch. i bought the camaro one. but thanks for the info. hey...i don't know if you guys know em, but my brother was iroc-5spd on this site. he had an 88 iroz-z camaro convertable. just sold it and got a 95 black coupe. well alright thanks guys
64goatman
Sep 9, 2015 01:09 PM
scotrans am
Sep 5, 2015 04:26 AM
85Special
Sep 3, 2015 04:21 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
