NEEd help: my engine get really hot
Old Jan 18, 2004 | 06:36 PM
cedric92300's Avatar
Car: camaro
Engine: v8 305 tbi
Transmission: at
NEEd help: my engine get really hot OK I GOT NEWS FOR THOSE WHO ANSWERED ME
hi
I CHECKED WHAT A FEW OF YOU HAD SUGGESTED AND WHEN THE CAR IS ON AND THE ENGINE IS HOT THE FAN DO NOT RUN
HOW CAN I MAKE IT RUN, HOW MUCH DO YOU THINK THAT SHOULD COST THANK FOR YOUR HELP AGAIN
HERE IS MY ORIGINAL POST :
i just got a 92 camaro tbiv8 with 90000 and i have a problem with the temperature of the car
when i in heavy traffic or stopped for a long time the engine get really hot to the point that the water coolant starts to boil
When i m on the highway no problem
everything is stock on it exept the 180 thermostat that i got which help a little bit
tycally do you guys think that it has to do with the radiator, the fan , the water pump or something else
what should i look for at first ?
thank for your help
Cedric
Old Jan 18, 2004 | 07:28 PM
Dave Y's Avatar
Car: 04 Xtreme Blazer
Engine: 4.3L V6
is your fan coming on?
Old Jan 18, 2004 | 07:57 PM
87z28camaro's Avatar
Car: 1987 Z28 Camaro
Engine: 305 tpi
1st i would check to see if ur fans comin on, if no then i would find out why they arent, if they do i would check ur radiator and water pump, if all good, then its prolly a head gasket, check ur coolant level, and notice if there is a white puff of smoke blowin out the tailpipes, kinda hard to tell in the winter time tho
Old Jan 19, 2004 | 01:56 PM
Kidane's Avatar
Car: 1987 Camaro RS
Engine: 2.8L V6 MPFI
Transmission: 700-R4
It doesn't really sound like a head gasket to me. My last car, a 1990 Rover Sterling, had warped/leaking head gaskets and it was fine in stop & go traffic, but on the highway was when I saw overheating problems.
I would say check your fans, make sure they're coming on, make sure you have a good 50/50 mixture and that your coolant hoses aren't blocked.
Old Jan 19, 2004 | 02:06 PM
KYL98's Avatar
Car: 1991 Z28
How hot does it get when you're just driving? I had that problem recently where my car never got above about 180deg driving....but in town would start to finally heat up. First I thought it was the fans not coming on, but turned out to be a stuck t-stat. Might check that, and also see if there's any air bubbles in your cooling system.
theshackle
Mar 5, 2017 06:37 PM
ezobens
Aug 19, 2015 10:29 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
