Who uses flexible coolant lines on their tranny?
Old Mar 21, 2004 | 04:24 PM
iroczrockz's Avatar
Car: 91 RS Camaro
Engine: 305 TBI
I was thinking about putting flexible coolant lines on my tranny but didn't know what size to use. Did anyone else use flexible lines? If so what size did you use. I am planning on using -4 stainless hose. I have -6 available, should that be used instead? If you have pics please post them. Thanks.
Old Mar 21, 2004 | 05:13 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
I used -6 on mine.
Old Mar 21, 2004 | 06:08 PM
iroczrockz's Avatar
Car: 91 RS Camaro
Engine: 305 TBI
Thanks, so no problems I guess. I have 24' of -6 and -4 so I guess I will use the -6 then. Thanks for the input.
Old Mar 21, 2004 | 10:38 PM
White91GTA's Avatar
Car: 1991 Trans AM GTA
Engine: 5.7L TPI
are you using those lines to replace the steel lines that come factory? if so, where can those be had at?
Old Mar 22, 2004 | 07:54 PM
iroczrockz's Avatar
Car: 91 RS Camaro
Engine: 305 TBI
I am going to be putting in a tranny cooler and you can get them with an fittings. I do plan to replace the factory lines. I just didn't know what line to use. I have some of that an stainless fuel/hydraulic line and wanted to put it to good use. It is the same fuel line you can buy from summit or jegs.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Stryker412
Sep 7, 2015 09:11 AM
TBRays98
Sep 6, 2015 05:05 PM
apie2546
Sep 5, 2015 07:40 PM
IROCZ1989
Sep 4, 2015 11:54 AM
