is it ok to bypass the oil cooler
Old Jun 18, 2004 | 10:20 PM
92rs85berlintta's Avatar
Car: White 25th Anniversary RS
Engine: lt1
Transmission: t56
Axle/Gears: 4:10
just need to know if bypassing the oil cooler on my friends tpi bird will hurt it.. it leaks and we cant get a new one yet.
Old Jun 19, 2004 | 12:26 AM
DuronClocker's Avatar
Car: 1997 Corvette
Axle/Gears: 2.73 IRS
I would imagine so... these cars don't have the most well-designed cooling system in the first place, so I would think that taking away from the cooling system at all could only make things worse.
Old Jun 21, 2004 | 11:37 AM
trans87's Avatar
Car: 2006 Tacoma X-Runner
Engine: 4.0L DOHC V6
Transmission: 6-Speed Manual
Axle/Gears: 3:15 LSD
I don't see how it would. My car never even came with the oil cooler from the factory and it's been fine. Ran the 305 and now the 350 without it and never had any trouble. If I remember correctly the stock oil coolers that were available did a lousy job of cooling the oil as it was.
Old Jun 22, 2004 | 10:07 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
the stock oil cooler is almost useless, and I doubt you'd ever notice a difference if you bypassed it. I bypassed it on my GTA long ago with absolutely NO difference that I could notice. My IROC never had one and I sure don't miss it.
Old Jun 22, 2004 | 10:12 AM
fb305svs's Avatar
Car: 1991Firebird T/A
Transmission: Modified Viper t-56
Axle/Gears: dana 44, 3.55
they work well for getting the oil to stabalise in temp, thats about it... they are not a "real" cooler, just pull it off
Old Jun 24, 2004 | 09:46 AM
Saigon_Bob's Avatar
Car: 1991 Camaro RS
Engine: 357cid
Transmission: T5 Swap
Axle/Gears: 10bolt 7.5" 3.23 soon to be 3.73
what does this cooler look like??
Old Jun 24, 2004 | 10:24 AM
fb305svs's Avatar
the oem cooler is a pancake stlye cooler which gos betweenthe filter and the block, and sues re routed cooloant to cool the oil.
Old Jun 29, 2004 | 04:01 PM
Eats5.0's's Avatar
Car: 84 Berlinetta
Engine: junk 350
Transmission: TH350
Axle/Gears: Moser 4.56
Looks like this. Right above the filter, two cooling lines to heater lines. Don't know if I have a pic of it connected.
Hotrodboba400
Dec 10, 2019 07:07 PM
tyeo098
Nov 30, 2015 06:27 PM
Formula8r89
Sep 22, 2015 04:24 PM
CatmanFS
Sep 19, 2015 09:00 AM
apie2546
Sep 5, 2015 07:40 PM
