Need AC electrical question answered or schematic for AC.
Old Jul 13, 2004 | 03:13 PM
dp149's Avatar
I need a wiring diagram or someone who knows what the (2) prong electrical connector wires do on the AC compressor. here is is my issue.
I have an 86 ta 305 4bl (lg4) the ac compressor is shot. the wiring for it out of the (2) prong connector is that one terminal has (2) wires coming off of it and heading back to the engine. The second connector has a wire that goes to the back of the ac compressor into a little sensor.
I found (what I thought) was the identical compressor out of a similiar junker in the yard but it doesn't have that little sensor in the back. What is this sensor? Can I use this compressor? what do I wire the other terminal to since their is no sensor on the back of the ac compressor?
Please if anyone knows I would really appreciate the advice. If nobody knows, can someone who has the service manual for this year car post the schematic for the ac electrical?
Thanks...
Old Jul 15, 2004 | 02:14 PM
tom3's Avatar
Car: 88 Camaro
Engine: L98 350
This is a high pressure cutout. Seems to be used on mostly cars with electric fans. You can jump across the two terminals, most early cars don't have this anyway. Don't know of anyway to add it to a compressor without one. Just make sure your fan is working right. Diagram for the 86 is a piece of crap, looks like a bunch of worms, real small too. This is a later model diagram that should be close to what you have.
Attached Thumbnails Need AC electrical question answered or schematic for AC.-acdiagram.jpg
Old Jul 15, 2004 | 02:48 PM
dp149's Avatar
Thanks Tom3...can you explain...
what you mean by this?
Old Jul 15, 2004 | 04:19 PM
tom3's Avatar
Car: 88 Camaro
Engine: L98 350
Wait, let me understand for sure what you have. Your old compressor that you're taking out has a pressure switch on the back of the compressor, two terminal with a plug in? This is a high head pressure cut out switch that is wired to declutch the compressor in the event the fans quit, or the condensor gets blocked, to protect the compressor and high side from ultra high pressure. Some older cars and cars with belt drive fans just don't have this cutout. To use a compressor without this switch on your car either cut the plug off and twist the wires together, or put a jumper between the two terminals to connect/shunt them. Might actually consider getting a correct compressor though, a rebuild is about 125 dollars most places.
Old Jul 17, 2004 | 08:53 AM
black89ws6's Avatar
Car: 89 Formula, WS6
Engine: LB9/peanut cam :(
clean the back of your replacement comrpessor. It may have a port for this switch. If it does, you can transfer the switch from your old compressor. Usually, they are only held in by a snap ring.
MustangBeater20
Oct 29, 2022 09:20 PM
Red iroc-z 305
Sep 30, 2015 05:22 PM
Bryan F
Aug 18, 2015 02:28 PM
redmaroz
Aug 16, 2015 11:40 PM
bamaboy0323
Aug 15, 2015 07:20 AM
