Temp sensor = bad emissions?
Old Jul 21, 2004 | 12:12 AM
sellmanb's Avatar
Car: '86 Berlinetta
Hey guys, I've been trying to pass emissions for the past week, tommorow will be my 4th time through there. I've done one quart of STP fuel cleaner in a full tank. and all the general maintenance (spark plugs, plug wires, rotor, dist. cap, oil, oil filter, air filter)
Well when I got the car a week ago, the temperature gauge is always stuck above redline, whether the car is on or off, key in or not. Does this mean that the temperature sensor is telling the car that it's always over heating and so the car is always running very cold? Would this make me run extremely rich as well?
I am replacing the O2 sensor tommorow morning hoping that it helps. But if this cooling thing is hurting me I'll need to get it fixed. I'm only getting like 12 - 14MPG right now, and the car wreaks of gas, but none is to be found around the air filter.
Old Jul 21, 2004 | 01:16 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
I believe the gauge and ECM use different senders.
Old Jul 21, 2004 | 01:52 AM
sellmanb's Avatar
Car: '86 Berlinetta
okay. Is there any way that I can check if the (EDIT) connection to the ECM from Temperature Sensor is working. W/O a scanning tool or laptop?
Old Jul 21, 2004 | 05:14 PM
dankhound's Avatar
Car: 91 RS
Engine: 305 Tbi (L03)
You can check the sensor for the ecm by probing the proper wire at the ecm. That will tell you what the voltage is at the ecm. It should be between .5 and 4.5v. If you have a tpi or tbi it will be a yellow wire in position c10.
As far is the gauge is concerned you probably a shorted wire somewhere. It could also be a faulty gauge.
Bstrang6
Sep 8, 2015 04:29 PM
nuggie
Aug 25, 2015 01:27 PM
theurge
Aug 21, 2015 12:46 PM
