i want to install a griffin rad into my 89 trans am but there is a problem with that
Old Jul 25, 2004 | 01:03 PM
jerflash's Avatar
Car: 90 Formula, 02 ws6
Engine: 305 tpi, ls1
Transmission: 700r4, t-56
Axle/Gears: stock posi 2.73, 12 bolt with 4.11s
if you look at the picture the griffin does not have the return port that the stock rad has and i heard from people to conect the hose to the pump but i ahve a newer reverse rotation pump and it does not seem to have a port to hook it to
is there anywhere else that i can hook it to or what?
thanks guy
joe
Old Jul 25, 2004 | 01:05 PM
jerflash's Avatar
forgot
Attached Thumbnails i want to install a griffin rad into my 89 trans am but there is a problem with that-hq4new.jpg
Old Jul 25, 2004 | 05:44 PM
CaptPicardsZ28's Avatar
Car: NCC-1701-D (docked in AZ)
Engine: impulse drive
Transmission: fusion reactors
Axle/Gears: Rescued from the Borg by my crew
Re: i want to install a griffin rad into my 89 trans am but there is a problem with that
thanks guy
joe
The intake or the water neck. You can get a water neck with threaded hole at any auto mparts store.
Old Jul 25, 2004 | 05:50 PM
jerflash's Avatar
the tpi uses that stupid waterneck that is diff then the regular chevy ones
where in the intake would i put it?
Old Jul 25, 2004 | 06:30 PM
John Millican's Avatar
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
Your waterpump has a heater core return port. It is probably plugged. Remove the plug and install the correct size heater hose fitting.
Old Jul 25, 2004 | 06:34 PM
jerflash's Avatar
im being serious when i tell you guys that i dont have a plug on mine it is a reverse rotation pump and if it is saposed to have one i dont know why is does not
Old Jul 25, 2004 | 07:07 PM
BretD 88GTA's Avatar
Car: Yes...
Engine: Last time I checked...
Transmission: See "Engine"...
The factory pumps do not have the port on the water pump. An aftermarket pump should come with a threaded port to attach the heater return hose.
Old Jul 25, 2004 | 08:14 PM
Dave Y's Avatar
Car: 04 Xtreme Blazer
Engine: 4.3L V6
yea, the reman on my car has the port, plugged right now, but it only cost like $20-$25
edit: I have seen remans without the port, so check at the store before you buy, if the first does not have it, keep looking at all the water pumps listed for your car at the store, at least one should hjave the port
Old Jul 25, 2004 | 08:29 PM
jerflash's Avatar
ya thats what i was thinking and considering that it looks like i have the original pump on my car i think i will change it when i do the rad
hey maybe i will throw a cam in also
Old Jul 26, 2004 | 09:39 PM
jerflash's Avatar
i checked with my local autozone and the highperformance pump has a port so im cool
i can get the rad then all i need is a trans cooler
oh and i picked up an 97 lt1 cam from a low miles car for 50 bucks and a set of rebuilt heads 081 casting same as my stock ones but new valves with valvejob, seals, springs, and was hot tanked, magna-fluxed, decked the whole 9 for 170
i got the heads so i dont have to have my car down for so long while i port these
sould make some nice sneaky power when done:rockon:
rocn7roc
Sep 21, 2021 02:16 PM
camaro11j
Sep 19, 2018 08:49 AM
84z96L31vortec
Aug 20, 2017 12:16 AM
gta power
Aug 13, 2015 06:15 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
