Condenser Swap???
Old Aug 5, 2004 | 02:21 AM
1985Camaro's Avatar
Condenser Swap???
I'm guessing my condenser is seized in my 85, but a guy from work has one from an 89 S10 Blazer...he's a mechanic and said if they looked enough alike in comparison then I should be able to change the assembly and use it. I wanted to see if anyone has any experience with it and if you think it can be done, thanks.
Old Aug 5, 2004 | 08:35 PM
1985Camaro's Avatar
yeah I screwed up, I meant to write the compressor not condenser...well if anyone has any idea let me know
Old Aug 6, 2004 | 07:44 AM
black89ws6's Avatar
Car: 89 Formula, WS6
Engine: LB9/peanut cam :(
It will work.
It may even work better. Typically, the truck compressors have a slightly smaller drive pulley, which will increase your compressor rpm.
Old Aug 6, 2004 | 11:07 PM
thirdgen88's Avatar
Car: 1995 Corvette
Transmission: 6 spd Manual
Axle/Gears: Dana 44, 3:45:1
keep in mind though that the 89 blazer will have a serpentine belt clutch assembly on the compressor, compared to your v-belt 85 camaro.. You'll need to change the clutch assemblies out.
theshackle
Aug 22, 2015 06:52 PM
Hello, Michael
Aug 20, 2015 03:19 PM
355sbcTPI
Aug 19, 2015 04:38 PM
Street Lethal
Aug 13, 2015 08:28 PM
Street Lethal
Aug 12, 2015 11:33 AM
