my engine is running waY TOO HOT SOMEONE PLEASE HELP
Old Aug 22, 2004 | 11:15 PM
theomen16's Avatar
Car: 1988 firebird
Engine: 305 tpi
---1988 FIREBIRD 305 TPI --- MY WATER TEMP IS READING PAST THE RED MARK ON MY GAUGE(OVER 260) I HAVE NO IDEA IN WHAT TO DO BUT I HEARD THAT IT SHOULD RUN CLOSER TO 220----THIS IS MY DAILY DRIVER AND IM SCARED OF OEVER HEATING.
Old Aug 23, 2004 | 12:16 AM
DJXero's Avatar
Car: 1992 Camaro Z28
No need for caps
Check to be sure the fan is running, it may have crapped out on you. It should be coming on when the temp is around 225 or so. Otherwise your thermostat may be stuck closed and not flowing coolant. I'd start there. Don't drive on it if it climbs into the red zone, you'll kill your engine.
Old Aug 27, 2004 | 12:47 AM
Jim Berry's Avatar
Car: '86 Trans Am
Engine: LG4
Axle/Gears: 3.70 Posi disc 9 bolt
1. Air Dam in place?
2. Fan working?
3. Replace radiator cap?
4. Water pump?
5. Thermostat inop.
Jim.
Azrael91966669
25
Jun 20, 2017 04:04 AM
theshackle
Mar 5, 2017 06:37 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
ZZ42Fast
Aug 10, 2015 08:20 PM
