freez plugs!!
Old Oct 14, 2004 | 01:49 AM
TheZ's Avatar
Car: 86 Iroc-Z
Engine: 5.0 TPI
freez plugs!!
I cant get my freez plugs out on the front of my block
ive been getting a scew driver and hammering it and the freez plugs are still not budging, yeah im denting it but thats it
any advise would be nice .thanx
Old Oct 14, 2004 | 12:35 PM
spartyon's Avatar
Car: 1986 camaro
Engine: 383 sbc
Transmission: th-400
Axle/Gears: 4th Gen 10 bolt/Detroit TrueTrac 4.
why are you taking them out if they aren't popped or broken?
Old Oct 14, 2004 | 01:44 PM
TheZ's Avatar
Car: 86 Iroc-Z
Engine: 5.0 TPI
Because im removing my cylinder heads.
Old Oct 16, 2004 | 03:06 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
There are no freeze plugs in the heads. Nor do you have to remove them in order to yank the heads. Leave the plugs in. There are other means of draining the coolant, if that is what your goal is. There should be a bolt/plug in either side of the block that drains the coolant.
Old Oct 17, 2004 | 11:53 PM
TheZ's Avatar
Car: 86 Iroc-Z
Engine: 5.0 TPI
I know ther are no freez plugs in my heads and i already took my heads off the coolant drained out of the head bolt holes under the exhaust manofolds.
Old Oct 17, 2004 | 11:55 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
so remove the drain plus on the block not the freeze plugs. but since you're hitting them and denting them already might as well remove them. they're soft metal and come out typically easily.
Old Oct 26, 2004 | 03:16 PM
rudyt5000's Avatar
Car: 87-Z r.i.p & 93-Z sold 99s-10
Engine: 305 TPI , 350 LT1, 2.2 4cylinder
Transmission: 700 R4, 4l60, ?
i had a leak in my freeze plug ...it took me a whole week to get one out...cause i didint have any tools ....the way i took it out was to make a hole ...i used a screwdriver and plenty of banging...but a drill would save alot of time...then get a pry bar a skinny one....i bought one at O REILLYS it came with two ......but once i made the hole big enough to fit the pry bar i pulled and pulled hard as hell till it popped out ....these freeze plugs were rusted pretty good.....i had to remove da starter and the y-pipe ...accidently dropped a socket in da y-pipe so now my muffler rattles like a rattle snake
wigmobile
Feb 26, 2025 02:56 PM
gta892000
Aug 11, 2019 11:16 AM
Stryker412
Sep 20, 2015 06:59 PM
Jlanz55
Sep 9, 2015 09:09 AM
89 formula TPI
Sep 7, 2015 11:06 AM
