Stock oil cooler?
Old Nov 1, 2004 | 11:12 PM
stingerssx's Avatar
Car: '88 Firebird Formula 350
Engine: Built 383 TPI
Transmission: Built 700r4
Axle/Gears: 9 bolt, 3.27:1 Posi
Stock oil cooler?
So in the process of swapping the motor in my Formula, I see that there is a stock oil cooler on the filter. I have heard that this doesn't really help out too much, and that it's pretty much pointless. Can I remove it, and what will happen (good or bad) once it's gone.
'88 350 TPI.
Thanks.
Old Nov 2, 2004 | 04:16 AM
89Warbird's Avatar
Car: 1989 GTA Nighthawk
Engine: 389 CID TPI
Transmission: TCI 700R4
Axle/Gears: 9 bolt 3.23
I chucked mine. As long as you're engine isn't running hot it has no noticeable effect.
Old Nov 5, 2004 | 10:38 PM
91banditt2's Avatar
Car: 1991 BandittII Firebird
Engine: 5.7 HSR
Axle/Gears: 3.27 9 bolt
i disagree every little bit helps.if ya got one i'd hook it up
Old Nov 6, 2004 | 05:22 PM
tom3's Avatar
Car: 88 Camaro
Engine: L98 350
There in SoCal, I'd keep it. These cars run pretty hot anyway, seems like, and getting the oil temp down a few degrees would help the life of the engine I'd think.
Old Nov 8, 2004 | 01:08 AM
stingerssx's Avatar
But does it really help? What I mean is that the hot coolant from the engine is what's trying to cool the oil. I think that if anything, it would keep the oil only as cool as the coolant.
So if that's so, (or no matter what anyway) wouldn't an aftermarket oil cooler be better?
I just don't see this cooler being worth anything. I mean, what other cars since have had them? LT1s don't.
Old Nov 8, 2004 | 01:23 AM
THEGENERAL's Avatar
Car: 1966 impala , 1998 sebring vert,1978 buick regal turbo, 1991 chevy silverado 3/4ton 4x4 lifted
Engine: 283, 2.5,3.8 turbo 350
Transmission: powerglide,auto overdrive, th350,4L80
yes an aftermarket is always going to do a better job on an oil cooler and a transmission cooler factory they wont get any cooler than the water temp that is leaving the radiator .....which is going to be cooler than what is in the engine if you didnt have a cooler at all but if your debating whether to purchase an after market cooler or leave the original id purchase an aftermarket one ..
on another note if your debating on taking off a good working cooler and chucking it for none then id leave the original
Old Nov 8, 2004 | 01:29 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Your oil will also take longer to heat up after a cold start without the factory cooler.
Old Nov 8, 2004 | 01:32 AM
THEGENERAL's Avatar
no that it wont ....
the oil will still warm up as fast it just wont cool
Old Nov 8, 2004 | 02:11 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Install an oil temperature gauge and compare somtime.
Old Nov 8, 2004 | 02:30 PM
f-crazy's Avatar
Car: Bright Red 91 GTA
Engine: CARBED LT4
Transmission: MK6
oil temp is 250-260 degress...coolant temp is 195-210...ive done the "testing" with an oil temp guage...without the oil cooler the oil is about 25-30 degrees hotter....LT1's and LS1's have an oil cooler...
Old Nov 14, 2004 | 01:18 PM
mystikkal_69's Avatar
Car: 1988 IROC-Z
Engine: L98 (350 TPI)
Transmission: MD8 (700 R4) + 3.42 LS1 Rear
he is correct. the "newer" LT1's and LS1's do have an optional oil cooler available.
Old Jan 14, 2005 | 12:23 AM
GTAfanatic's Avatar
Car: 1988 GTA Black notchback
Engine: 1991 L98 355 TWIN Superchagred
Transmission: 700r4 shift kit 2500 stall
Axle/Gears: www.cardomain.com/id/gtafanatic
How would i hook up a factory oil cooler? i have a vett L98 and the water pump has a 1/2 pipe comeing out of it,(GTA water pump douse not have this) this pipe is right above the the pipe that the lower rat hose goes on. anywaze the 1/2 pipe goes to a hose that goes to one end of the oil cooler the other ends goes right into the block
how would i hook this up with the gta water pump?
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
toronto formula
Nov 10, 2015 06:17 AM
Navy8125
Aug 21, 2015 09:32 AM
Exxon Limited
Aug 9, 2015 08:13 PM
