305 to 350 stock radiator too small?
Old Nov 27, 2004 | 03:38 AM
Orizon's Avatar
Car: 1984 Trans Am
Engine: BuiLt 350! Hooker 2055's
Transmission: T5-manual trans-centerforce clutch
ok i am putting in 350 in place of my 305 lg4. i have heard i should get a 3 vs the 2 row i have because the 305s run a lot cooler because they are bored small and a lot more room for water in the engine. i will be running the stock belt driven fan setup at least for the time being. will this not be enough to kool the 305. do i need to get a new radiator right away?
Old Nov 28, 2004 | 07:06 PM
xlwhellraiser's Avatar
Car: 1992 Trans/am convertible
Axle/Gears: 2.73 drum WS6
I was always under assumption that 305's came with a 3row radiator!!!
When I bought mine, it had a three row rad. Also, the direct replacement for it was a 3row radiator.
3row should be enough to cool a 350. However, I would get another fan if you only came with one, or you can get a 180 thermo drill some holes into it, and you will defenetly have a cooler engine!!!
Good luck!!
Old Nov 29, 2004 | 05:41 AM
1FastZ's Avatar
Car: 86 Iroc Z
Engine: 406
Transmission: 350 Turbo
Axle/Gears: 373
When I did my swap I left the factory radiator with one fan setup on my car. It keeps my 355 a cool 160 all summer long.
Old Nov 29, 2004 | 12:39 PM
Orizon's Avatar
Car: 1984 Trans Am
sweet. :lala: i'll see how it runs. when i pulled it i could tell its obviously not a stock radiator. its aftermarket. but if you made out fine with stock ill see hoe mine does with the one i got before i snag another.
Old Dec 2, 2004 | 12:10 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
I still run the 355 with the stock 305 radiator and single fan. It works beautifully. I never see temperatures above 160-165 with the fans on. Even with the fan off it stays cool. Still only a rebuilt water pump.
Old Dec 2, 2004 | 12:38 PM
vernw's Avatar
Car: 91 Formula WS6 (Black, T-Tops)
Engine: 383 MiniRam (529 HP, 519 TQ - DD2K)
Transmission: Built '97 T56, Pro 5.0, CF-DF
Axle/Gears: 4.11 posi Ford 9"
I'm running my 383 Super Ram with the factory 305 radiator and dual electric fans as well - was the 350 even different on these?
Old Dec 2, 2004 | 01:05 PM
z28monster's Avatar
Car: 86 IROC-Z
Axle/Gears: 3.42s/posi/disc
the radiaters are the same.... atleast my buddies radiater is exactly the same as mine and he has a 91 l98 and i have an 86 lb9
Old Dec 4, 2004 | 12:46 PM
Jproz1167's Avatar
Car: 1982 Trans Am & 1982 Corvette
Engine: L-98 with LO-3 induction. 350 CFI
Transmission: 5 speed and vette has 700r4
Axle/Gears: 373's in T/A .. vette unknown
wondering if any of you ever saw a factory 3 row staggered core radiator with plastic tanks, my 84 h.o had one like this when it was new, it also had a heavy duty cooling option
Old Dec 5, 2004 | 09:36 AM
Bill Speed's Avatar
Car: 1989 Formy droptop/88 Deville
Engine: L98 350 TPI
Transmission: factory RWD, WS6 susp
I just replaced the L89 V8 radiator...or will, with one from a 305 88 Camaro with auto trans...that's the sticking area I was told...needing those cooler lines!
Bill
jhawkeye
May 25, 2022 06:33 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
theshackle
Mar 5, 2017 06:37 PM
camaro71633
Sep 1, 2015 10:24 AM
st.evel07
Aug 13, 2015 06:15 PM
