Replacing with used
Old Dec 5, 2004 | 09:25 AM
Bill Speed's Avatar
Car: 1989 Formy droptop/88 Deville
Engine: L98 350 TPI
Transmission: factory RWD, WS6 susp
Replacing with used
I've been real busy as of late, hard to keep up with this, but my replacement radiator is from a 1988 Camaro via eBay as mentioned prior, with an embossed Modine logog
It has the trans cooler lines on the filler side, I have two questions, I have a bit of bent fins facing the engine that I need to straighten. I'm using a micro sized standard screwdriver to bend them and create space between each fin. I had started and then realized I was working ont the FRONT! side... It has a bit of work on the engine side I need to complete. Anyway, along with any suggestions and if pics are a good idea for others with this problem, I could take some.
The prior question is from a novice standpoint only having done one radiator replacement before, for the oil cooler lines, what do you use to avoid leaking of that...plugs and other suggestions?
Thanks again guys,
BILL
Out-Cast
Dec 31, 2015 04:40 PM
Dan Hubbard
Aug 12, 2015 09:05 PM
marcusaw
Aug 10, 2015 08:13 AM
Fronzizzle
Aug 9, 2015 01:15 PM
