Something has been cut off!
Old Dec 6, 2004 | 05:32 PM
chevymetal's Avatar
Car: 1985 Chevrolet Camaro IROC-Z28
I just bought my first F-Body about a month ago. (1984 Firebird SE) And I've been noticing some things about it. I am not an engine guy, and I see some things have been cut off of my car.
this has been cut right off, looks like with a hacksaw. Where does it go? Some cars it looks like it goes right back into itself? What is that piece? What does it do?
This comes from the radiator and looks like it's been cut off and pinched closed. Does the other part connect to this? Is it all part of the same circuit?
I have a lot of work ahead of me. But I think this will be fun. Can't wait 'til it's done.
Wait - they're never really done, are they?
the car -
Old Dec 6, 2004 | 05:41 PM
Joez88Camaro's Avatar
Car: 1988 Camaro Sport Coupe Convertible
Engine: Your Momma
Transmission: I can go forwards and backwards
It looks like the AC and the electrical have been hacked to hell. Plus there is lots of bad rust. I wouldn't put too much into that car.
Old Dec 8, 2004 | 03:28 PM
chevymetal's Avatar
Thanks for nothing. Anyone?
Old Dec 8, 2004 | 04:30 PM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
It's the refrigerant line from your dryer (at the firewall) to the coils in front of the radiator. Your a/c compressor was probably mounted above the ps pump on the drivers side. You can remove the coils and lines if you want-I wouldn't recommend trying to use them again if you ever want to reinstall a/c. Do a search for a/c delete. Rust doesn't look too bad.
Congrats on the new ride. Spend some time on here getting to know what's what under the hood, then start to work.
Old Dec 8, 2004 | 04:50 PM
89RS&98Z28's Avatar
Car: 1989RS////1998Z28
Engine: 305////350LS1
Transmission: 700R4////4L60E
The top pic is part of the AC system, the bottom may be also. You say comes from radiator, are you sure? The AC condenser is in front of the radiator, kinda looks like radiator too. So could also be part of AC system.
Old Dec 8, 2004 | 05:11 PM
nidyanazo's Avatar
Car: Gutted 92' RS TRACK ONLY / '86 Mustang gt 'vert / 1982 Yamiaha xs400 Cafe Racer
Engine: L03; TBI is IT! / 5.0HO (306) SFI / 400cc air cooled twin
Transmission: 700-r4 / WCT5/ 6-speed close ratio
They connect to eachother. Your a/c does not work because of this. Like you said, it IS all part of the same "circiut".
Old Dec 8, 2004 | 06:38 PM
Ramair21's Avatar
Car: Camaro RS/SS
Engine: 5.7 LS1
Transmission: 4L60E Transgo shift kit, 3500 stall
Axle/Gears: 4th Gen Rear 3:42
Looks like your going to have to do alot of work on that car. that is engine wise. good luck and if you have any questions this is the place to come bro!! GOOD LUCK!!
Old Dec 9, 2004 | 09:51 AM
chevymetal's Avatar
Ok, up here it's been to cold to use the A/C for cooling, but the heat in the car works fine. So that would make sense then. Thanks a lot! I planned on the work, and this place is definitely great. I've been using the search feature and answering almost all of my questions. I also signed up for that 3rdGen.org, and there isn't much of anything on that site. Not to mention their members are like the guy who replied first.
Old Dec 9, 2004 | 10:25 AM
naf's Avatar
naf
Is that a carbed 305?
Old Dec 9, 2004 | 12:11 PM
chevymetal's Avatar
You know, being brand new at all of this, I have no idea. I never got into cars until I had one, and that hasn't been too long.
Old Dec 9, 2004 | 12:46 PM
THEGENERAL's Avatar
Car: 1966 impala , 1998 sebring vert,1978 buick regal turbo, 1991 chevy silverado 3/4ton 4x4 lifted
Engine: 283, 2.5,3.8 turbo 350
Transmission: powerglide,auto overdrive, th350,4L80
look at his second pic posted it has a fuel pump on the block so id say yes its carbed....
Old Dec 9, 2004 | 12:51 PM
chevymetal's Avatar
I'm going to have to go with The General and say yes. A sticker under the hood for emissions hose routing shows an item labled "carb".
Old Dec 9, 2004 | 12:58 PM
naf's Avatar
naf
Fuel pump should have been a pretty solid indicator. Reason I asked is there are some excellent tech articles on the montecarloss site on computer controlled carburetors. They haven't answered all of my questions (still looking for a soo) but they're pretty good for a beginner.
MoJoe
Members Camaros
33
Feb 6, 2025 09:47 PM
SRKLEGIN
Interior Parts Wanted
Oct 12, 2015 07:28 AM
gord327
Oct 3, 2015 01:25 PM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
SRKLEGIN
Sep 30, 2015 07:19 PM
