Failed Thermostat
Old Dec 30, 2004 | 10:09 PM
V8 Slayer's Avatar
Car: 91 Firebird
Engine: 3.1 V6
Transmission: TH-700-R4
Failed Thermostat
What are symptoms of a failed thermostat?
Old Dec 31, 2004 | 12:33 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Failed as in how?
Stuck open: temp gauge shows cold.
Stuck closed: car overheats.
Old Dec 31, 2004 | 01:21 PM
V8 Slayer's Avatar
Car: 91 Firebird
Engine: 3.1 V6
Stuck open..Car barely gets above 100 Degrees as im driving.
Old Dec 31, 2004 | 01:37 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
That...would be stuck open alright.
Old Jan 9, 2005 | 01:05 AM
z28kindaguy's Avatar
Car: 2004 Pontiac GTO
Transmission: M12
Do replace it soon. Heat in the car will be almost non-existant, and the car will run richer.
Old Jan 17, 2005 | 11:52 PM
Jim Berry's Avatar
Car: '86 Trans Am
Engine: LG4
Axle/Gears: 3.70 Posi disc 9 bolt
My thermostat was failing itermittently, some days okay, others boiling over after a few blocks.
Sooo, I decided to replace it today and I snapped a bolt head off of the thermostat housing. No amount of drilling the bolt would allow me to use an "easy out" to get it out. I broke two drill bits trying to get into the bolt.
It looks like I may have to make a boneyard run to get a used intake and replace it. For now I have replace the thermostat and used a fair amount of gasket sealer and the remaining bolt to clamp it down. I'll fire it up tomorrow and see if it holds.
Stay tuned.
Jim.
Old Jan 18, 2005 | 02:31 AM
89Warbird's Avatar
Car: 1989 GTA Nighthawk
Engine: 389 CID TPI
Transmission: TCI 700R4
Axle/Gears: 9 bolt 3.23
JB Weld is your friend!
Old Jan 19, 2005 | 12:16 AM
Jim Berry's Avatar
Car: '86 Trans Am
Engine: LG4
Hmm, JB Weld.
I will still need a used intake though, if it holds.
I fired up the TA this morning and anti-freeze blew right out of the gasket.
If I use JB Weld, how will I create enough pressure on the thermostat housing while building up a weld on the bolt/hole in order to create a good seal? A pointed weight?
Jim.
Riding the city bus if the Thunderbird stops flying.
Old Jan 20, 2005 | 07:20 PM
Nitsuj86Iroc's Avatar
Car: 86 Camaro Iroc-Z
Engine: 305ci TPI
Even if you think your thermostat is messed up you may as well change it, they are cheep but important.
Old Jan 20, 2005 | 08:59 PM
Transmission: M12
:werd:
Old Jan 20, 2005 | 11:55 PM
Jim Berry's Avatar
Car: '86 Trans Am
Engine: LG4
I agree that changing it is important, but now I have a thermostat housing that I can't seal.
Jim.
Old Jan 21, 2005 | 10:08 PM
Jim Berry's Avatar
Car: '86 Trans Am
Engine: LG4
Update.
JB Weld? How about JB "Wont".
Tried to "weld" the housing in place to hold for a few days, but even after 24 hrs of curing the weld the gasket blew out again. Just not enought pressure provided by the weld to hold it in place.
I can't beleive my car is "down" due to one friggin' 14 mm bolt.
Unbelieveable.
Jim.
Old Jan 21, 2005 | 10:50 PM
Transmission: M12
About your broken bolt: I've used this trick quite a few times to get stripped bolts out. Take a Dremel and cut a straight line on the top of the bolt. Then, use a good flat screwdriver to turn it out. Sometimes some bolts require a lot of torque to get out, so I just put a pair of robo-grips or channel-locks on the screwdriver and it comes right out. Could be worth a shot.
Old Jan 22, 2005 | 07:11 PM
Jim Berry's Avatar
Car: '86 Trans Am
Engine: LG4
I might give it a try later on tomorrow.
Just looking at my previous post, my spelling is horrible.
Jim.
sheachopper
Jul 31, 2019 11:27 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
racereese
Oct 3, 2015 03:46 PM
6998poncho
Sep 25, 2015 02:56 PM
