melting switch?
Old Jun 10, 2005 | 11:54 PM
1meanGTA's Avatar
Car: 1987 GTA/1998 Explorer
Engine: 355, trick flow heads, zz409 cam, 3
Transmission: 700r4, shift kit, valve body
Axle/Gears: precision 3.73's, auburn diff
melting switch?
ok the guy i got my car from tells me that the switch for my cooling fans on my dash will melt if i hook up both my fans to it. it pops a 20 amp fuse everytime i try and hook them both up. i've never heard of a switch melting before. will i be risking a fire risk if i just pop in a 30 or 35 amp fuse and let it rip? wires melting maybe?
Old Jun 11, 2005 | 12:05 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Use a switch and wire rated for the current and it will be fine, or use the switch to turn on a relay rated for the current.
Old Jun 12, 2005 | 12:55 AM
Forshock 85TA's Avatar
Car: 85 Trans Am
Engine: 350 (CCC QJet)
Axle/Gears: 3.08 9 bolt
Use a relay, see the tech article or the sticky in this forum from willie... also if you search this forum under my username i have a diagram of how i did my system (it works pretty good )
Found the link: https://www.thirdgen.org/techbb2/sho...hreadid=291180
Veaceonee
Sep 29, 2016 08:15 PM
8889gtaformula
Exterior Parts Wanted
Nov 5, 2015 04:17 AM
RacerM
Sep 28, 2015 04:25 PM
327IROC85
Sep 23, 2015 12:11 AM
corey8084
Sep 17, 2015 02:56 PM
