cars getting to hot fan wont turn on is this why?
Old Jun 16, 2005 | 07:06 PM
f_body_4_life's Avatar
Car: 1988 formula
Engine: 93' LT1 Swap in progress..
well the fan wont turn on innless I turn the ac on it wont turn on by its self it almost goes in the red and still wont turn on but anyway I was wondering if this was why here’s a pic of what looks like a sensor with no wire I didn’t see any wires hanging down but anyway is this the cause of my problem?
Attached Thumbnails cars getting to hot fan wont turn on is this why?-127-2725_img.jpg
Old Jun 16, 2005 | 07:33 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
That looks like a low coolant sensor, or at least, where one would be.
Old Jun 16, 2005 | 09:59 PM
Speedgraphic's Avatar
Car: '90 RS Vert
Engine: 305 TBI
Transmission: 700-R4
That's not it!
Your problem is probably a bad or possibly unplugged Fan Switch. It screws into the water jacket of the block. Most likely it is on the passenger side just forward of your starter about half way up the block. There should be a wire plugged into it... You can change the switch out so that the fans come on at diffrent temperatures.
This is where I would look. Check wiring first.
Speedy
Old Jun 16, 2005 | 11:11 PM
Car: 1988 formula
ok it was plugged in I think I’m just going to order a new lower temp fan switch and see what happens
Old Jun 17, 2005 | 07:48 AM
Car: '90 RS Vert
Engine: 305 TBI
A bit of advice...
After I write this you will be thinking "that guy is stupid!"
If you read the instructions for putting in a fan control switch it tells you to drain your cooling system before you start. This is good advice - Do it!
When I did mine I had replaced coolant just a few weeks before and I did not want to drain. I thought - If I do this quickly how much could leak out? Let me tell ya - it flows fast. I was covered from head to toe or so it seemed!
SO - don't be stupid like I was - Drain the radiator first. It will make your life better.
Speedy
Old Jun 17, 2005 | 06:00 PM
sp63
Guest
Posts: n/a
my stock radiator didnt have that thingy on it i believe, but my repalcement (oem) did have it. i just elft it JUST like yours. no idea what its for.
RazorN8
Jan 7, 2022 11:44 AM
djmarch
Aug 9, 2015 05:27 PM
86Base
Aug 8, 2015 01:34 PM
Leggman1
Aug 6, 2015 04:15 AM
