Tranny cooler ?'s
Old Aug 25, 2005 | 07:03 AM
TKO500's Avatar
Car: 91 B4C, 17 C7 GS, 16 Denali DMax
Engine: LS3, LS3, LML
Axle/Gears: 3.23, 3.42, 3.23
Tranny cooler ?'s
I am installing a built 700R4 w/2400 Holeshot converter.
At the same time I would like to install a tranny cooler to keep it from getting hot.
I'd like to know which coolers you guys are running and where you mounted it. My plan is to still run the a/c so I will have the condensor behind the radiator.
The one I was looking at is the B&M cooler rated for 16,000lbs. The p/n in Summit is BMM-70255. Measures 11" x 5 3/4" x 3/4" for $42.88.
Seems this is a cheap insurance policy on my expensive tranny!
Old Aug 25, 2005 | 12:41 PM
paul_huryk's Avatar
Car: 1984 LG4 Camaro
Engine: 350 Roller Motor
Transmission: Level 10 700R4
Axle/Gears: Strange 12 bolt 3.42
External tranny coolers are always a good idea.
For every 20 degree fluid temperature drop, the life expectancy of the trans doubles. So a cooler than keeps the trans say 40 degrees cooler will make the life 4x as long.
I have the largest B&M supercooler - the extruded one, not the normal one. It keeps the fluid cool, yet doesn't overcool....
Old Aug 25, 2005 | 01:09 PM
firebirdjosh's Avatar
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
Speedingpenguin has one rigged up- he said it was dirt cheap as well.
TinnMann2
Canadian Region
16
Jun 18, 2017 05:10 PM
jrdturbo
Mar 31, 2016 02:58 PM
bjpotter
Oct 4, 2015 07:48 PM
FormulasOnly
Oct 2, 2015 05:52 PM
apie2546
Sep 5, 2015 07:40 PM
