just removed heater core..pretty easy
Old Sep 6, 2005 | 09:53 PM
dwillis's Avatar
Car: 1991 Trans Am Convertible
Axle/Gears: 3:08
I just removed my heater core to replace it today..I was scared to dive into it but..after i removed the dashpad and had a helper hold a mirror and a light...the infamous top screw in the heater box was really not all that hard to get to with a 7mm socket on a long 1/4" drive extension and a 1/4" ratchet...dont let some shop charge you 6 hours of labor to remove the dash when it doesnt have to be removed...really try it your self if you need to replace yours ...just wanted to share my exceitement with you all....
Old Sep 13, 2005 | 10:56 AM
rockit's Avatar
Car: 85 T/A, 92 Rs
Engine: L98:D,L03:<
Transmission: 700r4x2
Axle/Gears: 3.23 bw, 2.73 10 bolt.
WHOA what? it took me like,a day to swap my core what are you talking about? i had my dash completely out, console, dash everything.
Old Sep 13, 2005 | 11:06 AM
Forshock 85TA's Avatar
Car: 85 Trans Am
Engine: 350 (CCC QJet)
Axle/Gears: 3.08 9 bolt
Good job, feels good to do it yourself huh?
It took me the whole of 50 minutes to change mine out. Removed the lower "cover" and the "glove bag". Its not as bad as some make it sound.
(Typo)
Old Sep 13, 2005 | 09:05 PM
dwillis's Avatar
Axle/Gears: 3:08
yeah the shop manual calls for about 6 hours labor to do it...I cant afford to pay $500 to replace a $12 part...thats crazy...
Old Sep 13, 2005 | 11:49 PM
Rick King's Avatar
Car: 1987 TA
Engine: 350 stock/twecked
cool this is right up my ally
can you please give more details as I have never dived this deep into a 3rd gen before and I need to change a heater core in the ta
thanks
rick
Old Sep 14, 2005 | 11:03 AM
Car: 85 Trans Am
If you search for "heater core" you will find a few HOWTOs that use the "Fast" method. Keep in mind its not necessarily easier.
Old Sep 15, 2005 | 10:57 PM
dwillis's Avatar
Axle/Gears: 3:08
rockit
sorry i missed your reply,all i did was remove the core and replace my housing...my sister works at a parts distributor and i was going to get her price on one..plus i am running some cooling system flush in the cooling system before i replace the core because the coolant was like a rusty red color and i didnt want to put a new core in that...found out my sis cant get cores so i will have to go the autozone way i guess...
Old Sep 15, 2005 | 11:10 PM
Scheister's Avatar
Car: 85 IROC
yeah it was super easy, i replaced mine on a trip to FL. only took about an hour or 2 and the fact a new one was only $20 was the ****!
Old Sep 15, 2005 | 11:13 PM
dwillis's Avatar
Axle/Gears: 3:08
yeah man labor is what gets ya at a shop...glad im mechanically inclined in some areas
Old Oct 5, 2005 | 01:45 PM
84L69TA's Avatar
Car: 4 Mopars total
Engine: Pentastar power
Transmission: T/F and New Process
Axle/Gears: Three 8 3/4's & one 9 1/4
I replaced the one in my 84 in about 1/2 hour. They are very easy. Dont know about the Camaros though. Never done one of those.
Old Oct 6, 2005 | 11:09 AM
PhLaXuS's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Axle/Gears: 2.73 Posi w/Disc
I tried replacing mine earlier this year because the old one was leaking eekyookycoolantvapor and killing me slowly. The old one came out fast enough. I was scared to bend the pipes on the new one into place so after about 4 hours and still no new core, I connected the old lines together and returned the new unused core.
After this was all over, I heard that you're sometimes SUPPOSED to bend the pipes into place if they don't fit. You people who have had an easy replacement probably just got cores which were shaped properly in the first place. I have to tackle this task again in a month so I have some heat this winter. I live in south Florida but it still gets cold in February!
Old Oct 8, 2005 | 07:18 PM
dwillis's Avatar
Axle/Gears: 3:08
i just got thru installing my new one today.i didn't have to bend anything just had to line up the pipes with the holes then get out and look under hood to make sure they were lined up and pushed it in...it took about an hour by my self(this was after i removed my old one earlier this year...so the top screw is already goneIt works great but now i have to find a radiator leak...i think the previous owner used bars leak to stop the leak and with my extensive flushing i think i broke it loose...so i say oh darn i guess i,ll have to get an aluminum radiator to replace it
Old Oct 9, 2005 | 07:55 PM
pennylessz28's Avatar
Car: www.hrfbody.com
Engine: www.hrfbody.com
Good information being posted.
Frozer!!!
Jan 19, 2024 04:55 PM
greenyone
Aug 29, 2015 11:08 AM
TheExaminer
Aug 26, 2015 04:59 PM
Cheibu70
Interior Parts Wanted
Aug 15, 2015 12:11 PM
3rdgenparts
Aug 8, 2015 07:09 PM
