Dex Cool Antifreeze ????
Old Oct 17, 2005 | 09:11 AM
ck76239's Avatar
Car: 1982 z28, 2007 Silverado
Engine: 350 Chevy, 10-1 CR, Comp Cams 270h
Transmission: Th350,
Hi guys, I have a question, not about my z28, but about my daily driver, it's a 2000 Chevy S-10 4x4, with a 4.3l V-6.
Last winter, I noticed the heater didn't seem to putting out much heat, so I had the cooling system flushed.
Now, I turn to heat mode for the first time in the season, and no heat at all. I have a trusted mechanic (he was one my scoutmasters when I was growing up)I go to for work on our family car etc. He told me the Dex Cool stuff gets sand size kernals of crud in it, if not properly maintained. I asked if if he could switch it, and go back to ethylene glycol, but he said he wouldn't reccomend it...
So what's the deal with Dex Cool, what makes it go bad, if indeed it does?
Old Oct 17, 2005 | 09:50 AM
86IROCZ's Avatar
Hey, I have the exact same s-10 and the same thing happened to me too!
I had to flush it a couple of times to get all the sludge out. Its been working fine for the past year, but I yet to turn on my heater
Old Oct 17, 2005 | 06:12 PM
IROC212's Avatar
Car: 1986 IROC
Engine: 355 Tpi
Axle/Gears: 9 Bolt 3.27
I never had that problem in my thirdgen, but experienced it with my old Jeep. I flushed the system completely and put dex cool in it. About a year later the Jeep's radiator was full of red mud. I don't know why, but so much for 5 year coolant. I put green back in after a radiator replacement no problems now.
Old Oct 18, 2005 | 07:40 AM
ck76239's Avatar
Well, he backflushed the whole system, and now it heats great. I just hope it keep gunking up, because I dont want to pay to have the heater core replaced....
Are there any other alternatives to Dex Cool???
Ck76239
Old Oct 20, 2005 | 03:46 PM
PhLaXuS's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Axle/Gears: 2.73 Posi w/Disc
Is the GM requisite for DexCool that it's a new (like 97+) engine with an aluminum block?
Old Oct 21, 2005 | 09:08 AM
BMmonteSS's Avatar
Car: 84' Monte
Transmission: 700-r4
Axle/Gears: ferd 9" posi 3.50 gears
We had the same problem in our 99 blazer, red mud in the heater core. Like mentioned above just back flush the heater core and that should take care of it.
Old Oct 26, 2005 | 06:34 PM
tad1214's Avatar
Car: 1983 T/A
Engine: OUT (350 Block)
Transmission: 700-R4 sometimes
Axle/Gears: 3.23, moser 12 bolt >=3.73 someday
Just thought I'd chime in here. I work a t a Tires Plus this time of year we always check the coolant for temp resistance and cleanliness (spelling?) Anyways, dexcool always gets a gummy mucky residue to it. Just a radiator flush 90% of the time cleans it all out. Want to check if it needs it? Pull off the radiator cap (WHEN ITS COOL PLEASE!!!! Dont want a fellow thirdgener scalding there hand, ive seen it happen, its nasty.) and look at the rubber gasket, if it has a brownish residue on it, then its time for a flush. I dont know for sure but ive heard the multi use coolant that works in all types of systems doesnt do it as bad. Just another event that GM engineering is at work! Also, please dont mix the green in with the red, it has to be flushed then... if its low add water for the mean time. Remember to rotate your tires every 6000 or less miles! :-)
Old Feb 24, 2009 | 11:36 AM
MY87LT's Avatar
Car: 1987 Camaro LT
Engine: LG4 w/ SLP headers & a 3" catback
Transmission: THM700R4 (Stock)
Axle/Gears: Stock 2.73 gears. No Posi
Re: Dex Cool Antifreeze ????
Stay away from DEX COOL. Horrible nasty stuff.
Old Feb 24, 2009 | 11:40 AM
dave4x4's Avatar
Car: 85 Z28
Transmission: Auto.
I've been using Dex-cool in my 2001 Silverado and have never had a problem since day 1.
I hear that you're not supposed to mix the green and orange coolants, so if you go back to green, make sure to flush all the Dex-cool out, although this is probably easier said than done.
Old Feb 24, 2009 | 11:58 AM
SIEB77's Avatar
Car: 82 TA
Engine: Slighty built 350
Transmission: T10
most trouble with dex cool is when air gets into the cooling system. Thats when the crud will start building. Like on s10 pickups with the 4.3 when people ignore the leaking intake gasket it will usually crud up very soon after. Otherwise a very good coolant that will outlast green for a long time.
Old Feb 24, 2009 | 12:22 PM
safemode's Avatar
Car: camaro rs
Engine: 305 tbi and 350 on stand
Transmission: 4spd auto
dex-cool is crap. It was crap when they brought it out in their new vehicles and it's crap to even think about putting it in a vehicle that didn't come with it. It coats _everything_ in an orange film. It gets crud buildup like mentioned by others. It was meant to reduce maintenance between coolant flushes. I have pictures posted on here somewhere of my thermostat and radiator cap and such... i'll have to just look at the webserver sometime and re-post them.
Basically, dexcool reacts with air when hot and it undergoes a chemical change and the molecules start stringing together and becoming very large. This becomes the "cludge" that you see buildup. So any sort of coolant leak, benign or not, becomes the end of your use of dexcool.
It doesn't cool any better, it was meant only to prolong maintenance.
Old Feb 24, 2009 | 01:58 PM
redbird92''s Avatar
Car: 92' firebird
Axle/Gears: 10 bolt POSI 3.73's
Yeah i have a 1998 jimmy 4.3L and I have had that same problem after many attempts to clean with the name brand cleaners without much success with it.
I made my own cleaner and it is fantastic, cleaned the gunk beyond expectations maybe I will patent it someday
DEXA-COOL === costly repairs
Old Feb 24, 2009 | 02:07 PM
Aaron91RS's Avatar
Car: RS
Axle/Gears: 9" for the ladies
I took our 95z26 apart.
dexkill had coated the entire engine even below the water line.
blew out a head gasket and also previously had eaten up the usual lower intake manifold gasket..
The stuff is beyond garbage. I don't care if you keep all the air out. The stuff is crap and will cling to everything inside the engine even below the water line.
Where my heads meat the block, all the passages were 3/4 closed over from red crust.
GM got sued and lost for a reason. The stuff is garbage!
Old Feb 25, 2009 | 11:43 AM
MY87LT's Avatar
Car: 1987 Camaro LT
Oh I flushed the Dex Cool out of my car and made sure that I absolutely got all of it out. Took me pretty much all day, but I did it. I just did this a month ago and will flush the system again in a year just to be on the safe side. Seems like a waste of green (both fluid and money) but I dont want to take any chances.
Old Feb 25, 2009 | 12:28 PM
safemode's Avatar
Car: camaro rs
You'll be happier not having every damn thing in the car that touches coolant stained orange and encrusted with crap. That's a bigger waste of green.
Old Feb 25, 2009 | 01:54 PM
Wadebryant's Avatar
Car: 87IROC, 740iBMW, 328iBMW, 86GMC
Engine: 5.7, 4.4LV8, 2.8, 6.0
Transmission: Manuals & Auto's
Axle/Gears: 3.27, 3.42
Class action suit has been brought against GM reguarding DEX Cool. It may be too late now but, you may be entitled to reimbursement for repairs. It's up to you to do the research.
Start with a web search on the class action topic.
Old Feb 25, 2009 | 02:42 PM
igotta355z28's Avatar
Car: 1991 Z28 1LE
Engine: 370CID GenIII
Transmission: 4l60e
Axle/Gears: 4.33 Moser 9inch
DEXCOOL is a HOAT coolant or Hybrid Organic Acid Technology, The problem lies with the fluctuation of the pH of the coolant. The pH is supose to be a lil above about 11. If the ph rises then it becomes caustic and produces a scaling that covers everything and can lower the cooling efficientcy. And well if thats not bad enough if the pH gets lowered then the hole mix becomes accidic and will eat your engine from the inside.....
Old Feb 25, 2009 | 02:57 PM
1985blktransam's Avatar
Car: 1985 Firebird Trans Am
Engine: 5.0 Liter Engine
Axle/Gears: 3.08
Did not care for Dex cool myself. Recently upgraded my cooling system, New GM Radiator, Thermostat, Hoses ect.
Difference here, I went with Evan NPG + Waterless Coolant. Car runs cooler and does not need to be changed.
Con is that the system needs to be rid of any water. The other is the $30 per gallon price tag. For me ,well worth it. I converted my daily driver as well with Evan coolant. Since I was redoing it anyway, had the block drained and worked out well.
http://www.evanscooling.com/
And I do not work for Evans, I am in IT !!!!
Old Feb 25, 2009 | 03:22 PM
safemode's Avatar
Car: camaro rs
Running cooler probably has more todo with the new components than with NPG+. NPG+ will actually run hotter than the same system running on 50/50 regular coolant (assuming the engine is operating at normal temperatures). The deciding factor here is boiling temp and specific heat. As long as you can assume your engine will not have many local temperatures above the boiling point of your coolant, and that the avg temp is well below this temp, then the coolant with the higher specific heat will be best. Within the operating range of water, water is the best. If things get a little hotter than what water handles (like in car engines) then a mix with antifreeze is the best. If you get even hotter (or want to run hotter, as hotter engines are usually more efficient if they can handle the heat) then you use NPG+.
The reasons to use NPG+ have more to do with what you can do at the higher temperatures that would be dangerous with normal anti-freeze and water mixtures. In addition to the decrease in maintenance. It would not, however, give you a cooler running car for a normal application, it's just not nearly as good at absorbing heat as water and 50/50 type mixes.
http://www.evanscooling.com/main25.htm Pretty much sums it up.
Old Mar 4, 2009 | 11:30 AM
MY87LT's Avatar
Car: 1987 Camaro LT
It's all right for a company to develop a new product. But they need to bench test it more and really find out what the final effects will be instead of putting us through hell.
Linson
Oct 24, 2025 02:00 PM
sheachopper
Jul 31, 2019 11:27 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
ndndndnd
Sep 28, 2015 08:00 AM
bryan623
Sep 19, 2015 10:13 AM
