Just put on a 3.8 Taurus fan. (WOW)
Old Oct 30, 2005 | 09:26 PM
94-6spd's Avatar
Car: 83 Z-28
Engine: 406
Transmission: TH350
Axle/Gears: 3.70
Just made the swap from dual fans to a 3.8 Taurus fan that has dual speeds. This fan is awesome. It pulls so much air. I have a 406 with a stock radiator and when I kick on the fan the temp needle starts dropping fast. With the dual fans it would just keep it from going much higher. This is a very worthwhile swap. I got mine for $35 at a boneyard. You'll need a 40 amp relay and a 40 amp fuse. I pulls a lot of amperage. I toasted the 30 amp relay that was there previously. Also, the 40 amp relay was bought at Car Quest. The other part stores had only 30's. Anyone with an engine that runs warmer than they want should try this.
Old Oct 31, 2005 | 10:33 PM
dwillis's Avatar
Car: 1991 Trans Am Convertible
Axle/Gears: 3:08
what year tauras?
Old Nov 1, 2005 | 08:46 AM
Toehead's Avatar
Car: 1985 Berlinetta
Engine: Megasquirted TPI
Transmission: Transgo 700R4
probably an early 90's (old body style) SHO fan
Old Nov 1, 2005 | 02:30 PM
ditchbangr's Avatar
Car: One of 5
Engine: LB9
Or any of the 94+ mustang V-6-V-8 work great too. If you want a fan that really pulls get one from a Lincoln Mark VIII from the mid 90's. They really have wood!
94 6speed, do you turn the fan on by a toggle?
Old Nov 1, 2005 | 10:29 PM
94-6spd's Avatar
Car: 83 Z-28
Engine: 406
Transmission: TH350
Axle/Gears: 3.70
Early 90's taurus with a 3.8 liter engine. It will have 3 wires on it. That's how you'll know. One is ground, one is for low speed and one for high speed. From what I've heard is the Lincoln fan is the same part number as the taurus.
Old Nov 4, 2005 | 10:36 AM
SaintedCorrupt's Avatar
Car: '85 TA
Engine: Carb'd 350, ported 416s
Transmission: retrofitted T5
Axle/Gears: 3.42 7.62" 10-bolt, locker
this sounds like the perfect swap! set up low speed on a temp switch and high speed on a toggle...
what did you have to do to mount it?
Old Nov 4, 2005 | 12:09 PM
SatisTraction's Avatar
how did you wire up the two different speeds?
Old Nov 4, 2005 | 04:40 PM
94-6spd's Avatar
Car: 83 Z-28
Engine: 406
Transmission: TH350
Axle/Gears: 3.70
I had to take a sawzall and wack some of fan mounting flanges off and it fit right in. It looks factory. I didn't wire up the 2 speeds. I just wired the "high". It would be easy to do though.
Old Nov 5, 2005 | 08:52 PM
Cleve's Avatar
This swap sounds great. Do you have pics of the completed swap to give us a better idea of how it looks and fits. My dual fans just arent cutting it. Right now its not even hot and it runs at the 220 mark way to much for my liking. I have the lower fan switch that comes on at 200 and the chip turns the other fan on at 190. Thanks
Old Nov 6, 2005 | 06:33 PM
JP86SS's Avatar
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
Sounds Cool!
What is the diameter of that fan?
Old Nov 6, 2005 | 10:29 PM
7plagues's Avatar
Car: 92 Precision Red Firebird
Engine: v6->357 vortec xe262h rpm intake
Transmission: t5-> t56
Axle/Gears: 10bolt 3.42s
i did the swap. its not too bad i made a new harness for the fan and ran it to a 3way toggle High-auto-Low. its not to bad just research. fits really good, pulls alot of air.
Old Nov 7, 2005 | 02:43 PM
Car: '85 TA
7plagues: the three way toggle is a great idea. on your "auto" setting, do you have both speeds wired to come on at certain teperatures? if so, how did you do it?
Old Nov 7, 2005 | 06:14 PM
94-6spd's Avatar
Car: 83 Z-28
Engine: 406
Transmission: TH350
Axle/Gears: 3.70
I raced yesterday at the track and usually when I spray the temp gets up past 220. I used the fan and the temp was less than 180...this was with 75 degree weather. It is a 16in fan and here is a pic of my install.
Old Nov 7, 2005 | 11:04 PM
Car: '85 TA
wow, it probably pull air through the radiator better than ours because of that fan shroud, too. looks like that covers most of the radiator. wonder how well it would cover my griffin.
Old Apr 3, 2007 | 04:27 PM
94-6spd's Avatar
Car: 83 Z-28
Engine: 406
Transmission: TH350
Axle/Gears: 3.70
Re: Just put on a 3.8 Taurus fan. (WOW)
Old post I know but I'm now interested in how to do the 3 way switch with the relays. The switch could in no way handle the current draw of the fan on high speed and probably not low either. 7plauges care to explain.
Old Apr 3, 2007 | 05:30 PM
7plagues's Avatar
sorry forgot about this post lol, well i am using one of those cheap autozone 3ways, on auto it goes on at 180 with low setting using one of those cheap fan switches. you are correct though these switches cannot handle the load long, on auto its fine, but when i put into low or high it will only last a couple months. because it heats up and the toggle on the switch goes limp....piece of crap. anyway im in the process of trying to find a nice 3way or possibly rewirign to 2 switches on for low off(auto) and the other deticated to high.
Old Apr 3, 2007 | 05:59 PM
krisb410's Avatar
Car: 91 RS Camaro, 75 L82 Corvette
Engine: LO3, 383 Stroker
Transmission: 700R4, TH400
Axle/Gears: 4th gen 3.23 posi/LS1 discs, stock
I got one of these fans for 30 bux from a Junk Yard a while ago. A friend sent me this. Hope this helps someone. I hope to get around to it sonner or later.
File Type: pdf
Old Apr 3, 2007 | 10:00 PM
92rs365hp's Avatar
Car: 2011 dodge journey
Engine: v6 vvt
Transmission: auto
Axle/Gears: ???
how would you do this with a aftermarket temp gauge and manual fan switch??? this has got my attn my z runs 220 alot and I dont really like that
Old Apr 4, 2007 | 01:21 AM
7plagues's Avatar
heres what i did, its just a cheap temp sensor that switchs to a manual fan switch, its high off(auto) and low.
[URL=http://imageshack.us][/UR
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
AussiePr0nCar
Mar 6, 2020 04:04 PM
Jake_92RS
Jan 28, 2020 10:37 PM
sweet_87_iroc
Exterior Parts for Sale
Mar 27, 2016 04:05 PM
Fronzizzle
Aug 9, 2015 01:15 PM
