Custom/Aftermarket overflow tanks.
Old Nov 19, 2005 | 02:43 PM
Dialed_In's Avatar
Car: '88 IROC-Z medium orange metallic
Anyone been able to find a re-circulating catch can? Besides the cheesy ones from PepBoys. I can't see putting a stock one back under the hood of my car, but on the flip side of that I haven't been able to find any aftermarket ones that re-circulate, they're just catch cans. Just wondering whats floating around out there.
Old Nov 20, 2005 | 01:51 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
This is what I am using. Inlet on the top (the angled fitting), oulet on the bottom. Overflow lead being the obvious.
The problem with a recirculating surge tank design is you need some place that will draw the coolant back into the system.
You can try searching on eBay. There's probably some NASCAR take-off's on there somewhere.
Old Nov 20, 2005 | 03:51 PM
Dialed_In's Avatar
I was thinking of using one of the ones from ebay with the fitting the the top and using a compression fitting to run a piece of hard tube to the bottom so the fluid can be drawn back up.
Old Nov 20, 2005 | 04:14 PM
JesasaurusRex's Avatar
Jegs makes one
Old Nov 20, 2005 | 06:34 PM
Dialed_In's Avatar
Yeah but it's big, ugly and plastic. Definitely won't fit in my engine bay.
Old Nov 20, 2005 | 06:38 PM
huh, theyre made out of aluminum
1992 Trans Am
May 10, 2023 07:19 PM
Bohemian
Aug 15, 2017 05:11 PM
Strick1
Aug 27, 2015 08:57 PM
mat89RS
Aug 23, 2001 12:47 PM
Jza
Mar 2, 2001 09:53 AM
