Overflow Tank Needed
Old Mar 20, 2006 | 04:12 PM
BadGirlIROC's Avatar
Car: 87 IROC-Z
Engine: 355 carb'd
Hey guys,
I still really need an overflow tank but just do NOT want to have to use the stock one. There has got to be an alternative that looks much better and can be put elsewhere. I just got my car done and would prefer to leave it as clean looking at possible. I have looked a million different types of overflow tanks and like the Jaz ones or just the plain black Summit one but apparently those aren't really recirculating tanks like the stock one is. Why are these different and can someone please suggest one that would work properly?
Thanks so much!
Old Mar 20, 2006 | 05:40 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
I remember when I was looking for components for my cooling system, I came across one from Jeg's that could be rigged as either petcock or recirculating. Nice aluminum looking, IIRC.
Old Mar 20, 2006 | 05:54 PM
eXesiv|83ta's Avatar
Car: 1983 Pontiac Trans AM
Engine: 355 chevy
Transmission: 700R4 Built
Axle/Gears: Built 10 bolt 3.73 gears
ya I would use an aftermarket one.
Old Mar 20, 2006 | 07:29 PM
daves12secV6's Avatar
i can fab one for u out of stainless or aluminum if ya like heres one i just did for the rs
the one i did for the rs recirulates,and has overflow tube pointed at the ground
btw in those pics it isnt polished yet
can make them any size/any capacity, with mounting tabs were ever u like
Old Mar 21, 2006 | 06:36 PM
@ZZKKER's Avatar
Car: 86 iroc, 87 iroc, 89 iroc, 89 formula, 84 supra, 85 trans am
Engine: t\a motor 355 lt1 intake, t56,the works, 89 roc 427 sbc tt project
Transmission: to many to list
Axle/Gears: 9bolt 4:10 in the T/A
moroso makes one that is the recerculating type. i have it on my trans am. i had to polish it, but looks good. MOR-63660 is the summit part number. dont have any pics yet, but i mounted mine by the radiator cap on the an shroud with a custom bracket i made. only draw back is that it is a 1 quart capcity, so i dont know if it will be enough ( have not driven car yet). time will tell.
thanks
anthony
Old Mar 21, 2006 | 11:04 PM
the one i mad epoictured above has just over 1 quart capacity and i have yet to have it overflow
Old Mar 21, 2006 | 11:26 PM
@ZZKKER's Avatar
thats good to hear
thanks
Old Mar 22, 2006 | 09:36 AM
Car: 87 IROC-Z
Engine: 355 carb'd
I thought the tank had to be up and down and couldn't be sideways like that? Does that one just drain out the bottom or does it really recirculate??
Old Mar 22, 2006 | 06:40 PM
no it can be mounted like that, the line on the driverside on the bottom is the fill/return line. the other line is just incase it pumps out more then the capacity of the can, it will overflow onto the ground instead of the paint, its been doing fine on my car, same thing as the ones u buy from summit,just mounted differently.i can make them any capacity, and add mounting tabs so it can be mounted anyway the person wants. mines mounted liek that so my intercooler fits in below it
Old Mar 26, 2006 | 05:43 PM
Car: 87 IROC-Z
Engine: 355 carb'd
Thanks for the replies!
I ended up getting the Moroso recirculating tank and had it mounted today.
You can see it in the bottom corner of this shot
1992 Trans Am
May 10, 2023 07:19 PM
IROCZ1989
Jan 24, 2016 03:55 PM
kitt23
Exterior Parts Wanted
Aug 15, 2015 12:37 PM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
