overheating on an l03
Old Apr 19, 2006 | 05:58 AM
flaming-ford's Avatar
Car: 89 iroc-z
Engine: 305tpi
Transmission: wc-t5
Axle/Gears: 10 bolt 3.08 posi (4 now)
alright guys i've got a 1992 camaro rs 305 tbi engine basically stock except aircleaner and chrome. My car has now overheated on me in countless occassions, i've replaced the waterpump, and thermostat and the radiator is an aftermarket 2 or 3 row modine radiator which looks to be very new (no dings dents or anything yet). I'm basically running all water in the system right now and the only thing i could figure is my radiator cap wasn't pressurizing properly but, after buying a new 1 and installing it i'm still quite doubtful that is my problem.
The only problem i can really find with the coolant system so far is it has the typical steady intake manifold coolant leak on the front edge of the block. I'm lazy and i realy would rather not have to pull it and regasket it plus it's my daily so i'd much rather i didn't have to. I guess if i have any more problems i'll try pouring a thing of radiator stop leak in it and hope that it seals (most doubtful the leak is fairly steady).
O btw yes my fan is kicking on at the proper temp 220-225*. The t-stat is also opening at 195* as it should.
My only 2 thoughts are maybe i have a slightly blow headgasket at the front of my engine on the driversid along with the intake manifold leak or #2 the leak is substantial enough that is bleeding off all the pressure the system is under causing it to boil.
I did pressure test it and yes it does bleed off pressure but, it takes it about half an hour to do so, so i guessed most likely it would bleed that much off through the pressure tester fitting (could be wrong here).
Anyways any advice is helpful thanks.
Old Apr 21, 2006 | 01:11 AM
iroc22's Avatar
Have you checked your timing? What condition is your airdamn in?
Old Apr 21, 2006 | 05:37 AM
techno101's Avatar
Car: 1989 Camaro RS
Engine: Modified 350 TPI
Transmission: Modified 700 R4
Axle/Gears: Posi 3.42
Make sure your air dam is in place, not torn apart. You will see a 50-75 degree difference with a factory style air dam.
Old Apr 21, 2006 | 05:55 AM
Car: 89 iroc-z
Engine: 305tpi
Transmission: wc-t5
air dam is good and in place but, timing is 10* advance i have played with the base a lot and i know that's a lot of base timing especially for this engine but, it performs best with the 10* base. It has 145k miles on it so the chain has 4* of stretch approximately therefore it's basically like running 6* btdc timing.
ps i got rid of my coolant diverter valve and routed it to the heater core all the time and bought a new radiator cap and haven't had a problem since.
Old Apr 22, 2006 | 11:52 PM
MikeDirntRulez's Avatar
Car: 1990 Camaro RS
Engine: 305 TBI (L03)
Transmission: 700R4 (MD8)
Axle/Gears: 2.73 Open (GU2)
10* is waaaaaaaaay too far advanced for a stock TBI engine. You shouldn't be running more than 6*.
How do you know it's running well? Your knock sensor is probably having a good time, i'm not even sure 91 would combust properly at that great of an advance. Have you datalogged it? Getting any knock counts?
Please do yourself a favor and retard your timing a bit... that might be your problem right there.
Old Apr 23, 2006 | 08:39 PM
Crusin' 1980's's Avatar
Car: 1988 SC Camaro
Engine: 305 TBI
Transmission: 700-R4
Ya, that is quite a bit...6 might even be pushing it, but I wouldn't go any higher than 6.
Old Apr 23, 2006 | 08:48 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
If his intake is leaking coolant, could it also be leaking inside, and filling the oil with coolant, watering it down? I know when you remove the intake, the coolant flows into the lifter valley, and into the oilpan.
Old Apr 26, 2006 | 05:41 AM
Car: 89 iroc-z
Engine: 305tpi
Transmission: wc-t5
Alright the distributor says 10* advance but, it's only truly getting 6* advanced because, after 145k miles the timing chain has stretched about 4*.
No it's getting no knock counts on 87 octane and yes it does run best at 10* i've played with it a whole whole lot.
No that's not happening for sure but, thanks for the idea and keepem coming.
I replaced the radiator cap and got rid of my coolant diverter valve and have coolant running to the heater core all the time now. Haven't had a problem since this but, the problem was only simulataneous before so we will see.
Last edited by flaming-ford; Apr 26, 2006 at 05:42 AM. Reason: Automerged Doublepost
Old Jun 2, 2006 | 02:45 PM
mdurbala's Avatar
Car: 91 Camaro RS
Engine: 305 tbi
have you had any problems since, my car is doing the exact same thing and im pretty dumfounded on what the hell is going on
Bubbajones_ya
Jul 6, 2024 08:32 PM
Jake_92RS
Jan 28, 2020 10:37 PM
sheachopper
Jul 31, 2019 11:27 AM
anesthes
Sep 21, 2015 10:24 AM
mustangman65_79
Sep 1, 2015 03:51 PM
