Overheating and blowing fuses
Old May 1, 2006 | 05:27 PM
gp423's Avatar
Car: 1989 Firebird Formula
Engine: LB9 305 tpi
Axle/Gears: open 2.73's baby!!
This problem arose recently, when i first got the car on the road it ran like a champ and never went above 220 even when beating on it badd. all of a sudden i cant drive it in traffic for more than 10 minutes or so before the gauge freaks out and i get scared and pull over lol. my coolant is clean and flows well, i put in a new 180* thermostat recently didnt help any. also the fans dont come on, and i replaced the fuse for it and i keep blowing it, it even blew a 30 amp fuse i had to throw in out of desperation(no where to pull over). what exactly would cause this? both fans work when the fuse is alive. is it possiable to wire them so that they are on all the time for added cooling or is there some sort of problem with that? thanks for any help guys! my car is a 89 firebird with a 305 TPI and 700r4 with dual electric fans.
Old May 3, 2006 | 02:34 PM
gp423's Avatar
Engine: LB9 305 tpi
anyone? even a vauge idea? im gonna take another look this weekend, all the wiring looks fine from what i can tell. maybe a relay is bad? anyone please!
Old May 6, 2006 | 11:14 PM
Blue_IROC_86's Avatar
Car: '82 Camaro Z28 (Former Pace car)
Engine: 85 5.7L Small Block
Transmission: WC T5
Axle/Gears: 96 disc LT1 3.23 Auburn 10 bolt.
blown fuses only mean one thing. system overload!. there is probly a short somewhere in the harness. or it is grounding out somewhere. look for broken wire insulation, or stripped wires touching metal. if this fails (however unlikley) then both fan motors are bad. trust me electric fans are pushy
3rd gen money
Oct 11, 2019 09:57 PM
sheachopper
Jul 31, 2019 11:27 AM
thunder57
Nov 7, 2015 02:28 PM
Fanatic1074
Oct 2, 2015 03:47 PM
lanceflame44
Sep 25, 2015 12:28 PM
