Cooling headache
Old Jun 25, 2006 | 05:04 PM
madathlon's Avatar
Car: 1988 Camaro, 1960 F-100
Engine: 2.8L V6, 223 inline 6
Transmission: TH-700R4, T98
Axle/Gears: 3.42/3.11 Posi Lock
Cooling headache
Ok I just fix my A/C system.. And up intill then the car been running just right.. About 200* all the time.. The day I got the A/C fix I over heated major time and blow the rad.. The only think I can see wrong is I have no air dam at all ( Looks like there never been one.. I have a 88 with the 2.8 .. Any advive on what to look for once the new rad in?
Old Jun 25, 2006 | 05:32 PM
firebirdjosh's Avatar
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
My car ran 220-240* without the air dam, and 180* consistantly with the air dam. I hope that guides you in the right direction.
Old Jun 25, 2006 | 05:55 PM
madathlon's Avatar
Ya, I been reading thru thr Cooling forum and it seems that little piece of plastic make a big diffrence.. But it really looks like there never been one on this car..
Old Jun 25, 2006 | 06:07 PM
Toehead's Avatar
Car: 1985 Berlinetta
Engine: Megasquirted TPI
Transmission: Transgo 700R4
my 85 2.8 doesnt have an airdam either, and no holes indicating there ever being one... Runs cool, so I havnt bothered with it yet.
Old Jun 25, 2006 | 06:11 PM
madathlon's Avatar
Toehead? Does ur 2.8 have A/C? Im starting to think the A/C is what cause mine to overheat.. Because it never did intill I fixed the A/c
Old Jun 25, 2006 | 06:31 PM
Toehead's Avatar
It has ac, but as of yet the compressor just cycles on and off very quickly, and doesnt get cold. I plan to convert it soon, once i can find somebody to suck out the r-12
Old Jun 25, 2006 | 06:36 PM
madathlon's Avatar
Let me know what happends when U get it fixed...
Also.. I have notice there a lot of ducting ( I think thats what it is ) On other camaro's About 1/2 why up the rad. mine is missing.. will this cause a problem also?
Old Jul 2, 2006 | 04:39 AM
troy_durr2000's Avatar
Car: 87 camaro
Engine: 2.8 V6
Transmission: 700 with overdrive
about the overheating
I was wondering if u ever found out the problem with u r overheating I have an 87 camaro 2.8 same thing i fixed the a/c and right about when it gets cool in the car it overheats only when the a/c is on
I also live in vegas dont help matters but yea only when the a/c is on dont get it hope u got u rs fixed
Old Jul 2, 2006 | 09:55 AM
madathlon's Avatar
Ya I did. I spilt my rad on one side.. soldered it back up and its running agian.. Added the air dam and its running 20* cooler
Old Jul 6, 2006 | 05:24 PM
Toehead's Avatar
Hey. Fixed my a/c yesterday. Still no airdam, doesnt run any hotter with the a/c off versus the ac on. Vent temperature is about 37 degrees
Old Jul 6, 2006 | 06:23 PM
madathlon's Avatar
thats cool.. I added the Manual fan switch and now im running 160* all the time.. And its so nice
Old Jul 7, 2006 | 12:48 AM
Toehead's Avatar
The manual fan switch is NICE. I usually just leave mine on
Old Jul 8, 2006 | 11:34 PM
Car: 87 camaro
Engine: 2.8 V6
just wondering what an air damn is and if i can add one
just wondering what an airdam is and where does it go and if mine dont have one is it easy to add?
Old Jul 9, 2006 | 09:41 AM
madathlon's Avatar
Originally Posted by troy_durr2000
just wondering what an airdam is and where does it go and if mine don't have one is it easy to add?
The Air dam is a piece of plastic on the bottom or the Rad support under the car.. it creates a vacuum under the car as you travail and helps pull air thru the rad as U travail down the road.. And yes it is easy to install.. just 6 self tapper bolts..
Old Jul 10, 2006 | 10:52 AM
dwint's Avatar
Car: 88iroc
Engine: 355 blueprint engine
Transmission: raptor built 700r4
Axle/Gears: 373
cooling
it is suppose to do that when you need a recharge.it does that so it doesn't burn out your compresor.i just put a pin in mine to get rid of the r-12 and fill with 134.had it over 3 years without any problems
Old Jul 10, 2006 | 06:47 PM
k's89rs's Avatar
Car: 89 rs, bmw 325 is
Engine: 360 (.060) 2.5L inline six
Transmission: 700r4, 5-speed
Axle/Gears: 9 bolt 3.08 3.? limited slip
if anyone blows their radiator out, i suggest spending the 250 dollars for the summit brand aluminum radiator. yeah its two times more expensive than an aftermarket radiator, but it doesnt have the plastic side tanks. i have noticed a dramatic difference in cooling with the radiator. just my two cents...
kent
Linson
Oct 24, 2025 02:00 PM
sheachopper
Jul 31, 2019 11:27 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
ndndndnd
Sep 28, 2015 08:00 AM
64goatman
Sep 9, 2015 01:09 PM
