Over Heating
Old Jul 19, 2006 | 04:48 PM
juggaloblazed's Avatar
Car: 89 TA
Over Heating
I'm havin a hell of a time with this one car I changed the radiator the waterpump, thermostate, radiator cap , and its timed right. But after all that the **** still overheats it goes above 220 but not all the way pined. It olny get hot when I'm on the thruway or roads over 45. and also when I give it heavy gas. Can Anyone give me some pointers cuz i'm all out of Ideas I even changes the fans to one big one Instead of the two but nope still overheats.
HELP PLEASE
Old Jul 19, 2006 | 05:07 PM
Stealthy-One's Avatar
Car: 89 RS
Engine: 2.8
Transmission: 700r4 auto
Axle/Gears: huh?? guessing stock.
do you have the air dam installed? at speed that is what diverts air from under the car through the rad. with out it, or if it is damaged you will get HOT when at speed.
New one is only like 20-40 at the dealership.
Old Jul 19, 2006 | 05:09 PM
BlkBird408's Avatar
Car: 89 Firebird
Engine: 408
Axle/Gears: 12 bolt/4.11
Well how does the drive belt look?? It could be slipping and not letting the water pump function properly! You may also try flushing your cooling system and refilling to see if that might help. Do you have your air dam installed?? Just a couple thoughts.
Old Jul 19, 2006 | 05:16 PM
Forshock 85TA's Avatar
Car: 85 Trans Am
Engine: 350 (CCC QJet)
Axle/Gears: 3.08 9 bolt
airdam
Old Jul 19, 2006 | 10:42 PM
Car: 89 TA
Its a 86 TPI. The belt seems fine no slipping I flushed it too.
Old Jul 20, 2006 | 09:22 AM
Car: 89 TA
whats the timing got to be set at with a 305 manual
Old Jul 20, 2006 | 06:38 PM
Car: 85 Trans Am
Look at the emmissions tag under the hood. anywhere from 0-6 BTDC.
Old Jul 20, 2006 | 09:34 PM
Car: 89 TA
The car used to be a 6cyl and the hood is diffrent and no tag
Old Jul 20, 2006 | 10:18 PM
smokefan's Avatar
Car: 86 IROC w/Danko bodykit, 1988 iroc vert, 1989 k1500 pickup 6" lift and 35" tires, 2002 chevy tahoe z71
Engine: 383 stealth ram, 305 tpi, 350 tbi, 5.3l
Transmission: T56, 700r4, 700r4, 4l460
do you have the single or duel fans. i was having an overheating problem with mine also and was told to switch to the single fan set up and it solved all my overheating problems.
Old Jul 20, 2006 | 11:10 PM
Car: 89 TA
I had the dual fans but switched it to the single still no change. i'm gonna check the timing again.
sheachopper
Jul 31, 2019 11:27 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
mfp189
Sep 27, 2015 09:25 AM
bryan623
Sep 19, 2015 10:13 AM
