Stock trans cooler, can it be used for oil?
Old Jul 19, 2006 | 10:57 PM
walterrao's Avatar
Car: 91 RS
Engine: vortec 355 hsr
Transmission: wct5
Axle/Gears: bg3.27
I have an aluminum radiator out of an iroc that was an auto, so it has a trans cooler in it. Im wondering if i can use this as an oil cooler. im pretty sure it would work, but im not sure if the lines are too small, or if it would be able to carry enough volume. Any insights would be appretiated. Thanks
Old Jul 20, 2006 | 11:36 PM
walterrao's Avatar
Car: 91 RS
Transmission: wct5
Axle/Gears: bg3.27
i guess this is either a dumb question, or not alot of people have tried this.
anybody?
Old Jul 22, 2006 | 08:05 PM
ScottyRS's Avatar
Car: 1992 Camaro RS
Axle/Gears: Stock
I don't recall any of these cars coming with a trans cooler from the factory. That's all I can say on the matter...
Old Jul 22, 2006 | 11:20 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
The metal lines on the passenger side of the tranny going up to the radiator are the tranny cooler. Its inside the passenger-side tank of the radiator.
I thought about doing this too but never seriously considered it.
Old Jul 24, 2006 | 01:12 PM
Forshock 85TA's Avatar
Car: 85 Trans Am
Engine: 350 (CCC QJet)
Axle/Gears: 3.08 9 bolt
Well looking at different engine oil coolers, the lines are usually 1/2" or better.
If i remember correctly, ??, trans lines are 5/16"
Old Jul 24, 2006 | 02:07 PM
firebirdjosh's Avatar
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
Yeah, I'd get an aftermarket cooler becuase: 1. better flow, 2. shorter oil lines.
Old Jul 26, 2006 | 10:40 PM
walterrao's Avatar
Car: 91 RS
Transmission: wct5
Axle/Gears: bg3.27
well thanks guys, i guess it probably wont flow enough volume which could possibly end up in some spinning bearings, that would suck. thanks again for telling me before i tried.
-walter
Old Jul 27, 2006 | 12:44 AM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
noobs
rofl
thats all i have to say on this matter, hehehee
im just playin around :P
maroe624
Apr 16, 2017 08:29 AM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
Navy8125
Aug 21, 2015 09:32 AM
TreDeClaw
Aug 14, 2015 06:58 PM
Exxon Limited
Aug 9, 2015 08:13 PM
