Hypertech cool fan switch, problem
Old Aug 23, 2006 | 09:29 PM
roc88's Avatar
Car: 88 Chevy Camaro Iroc
Engine: 5.7 tpi
Transmission: 700-r4
Hey guys, I just bought a Hypertech cool fan switch for my 88 Iroc 5.7 TPI. It's supposed to turn on the fans on at 176 degrees and off at 165. My problem is the fans still do not kick on until around 225. I didn't change the thermostat yet so I am still useing the 195 degree stat. Is this my problem why the fans are not kicking on at 176, or is it something else?
Old Aug 23, 2006 | 09:58 PM
ChrisColeman's Avatar
Whats the part number of the switch you bought?
Is the system full, bled and leak free? Only other reason It wouldnt be kicking on.
Thermostat has no effect on the fans man.
Old Aug 24, 2006 | 12:57 AM
LAFireboyd's Avatar
Axle/Gears: 9-bolt/3.45
The fan switch you installed only operates the secondary fan, not the primary fan.
The primary fan is operated by the ECM. And unless you changed its programming, it's still operating at the stock-programmed temp, which is approximately 225*.
Old Aug 24, 2006 | 07:17 AM
I think an 88 Iroc only has one electric fan.
Old Aug 24, 2006 | 07:22 AM
roc88's Avatar
Engine: 5.7 tpi
The system is full with a 75/25 mix, no leaks anywhere. The part # is 4026. The secondary fan still isn't kicking on at 176. Maybe I got a bad switch. Thanks guys!
NBrehm
Aug 25, 2015 11:49 PM
Bryan F
Aug 18, 2015 02:28 PM
TA8487
Aug 16, 2015 12:21 PM
Fronzizzle
Aug 9, 2015 01:15 PM
Leggman1
Aug 6, 2015 04:15 AM
